Maintenance Advice on my new Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Annapolis-Tim, Sep 5, 2019.
  1. Sep 5, 2019 at 3:00 PM
    Annapolis-Tim
    Annapolis-Tim [OP] Member
    Tim
    2013 Tayota Tacoma
    I just picked a second hand 2013 Tacoma a couple of weeks ago. Coming from an old Jeep Wrangler - i love having a pickup truck. Im looking for a little advice. I try and do all mechanic work on my own cars and have a good selection of tools. Im definitely not an expert but can turn a wrench. Im basically looking for a list of things I should have a look at and see what sort of state it is in. The truck has 150k miles on it and seems to drive pretty well. Any advice from you folks would be definitely appreciated.
    Thanks,
    Tim
  2. Sep 5, 2019 at 3:02 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum!
    Bigdaddy4760 likes this.
  3. Sep 5, 2019 at 3:03 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
  4. Sep 5, 2019 at 3:17 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Welcome to the forum.
    Very nice looking Tacoma :thumbsup:
    Personally I'd Check/replace the air filter and cabin filter. The latter usually gets ignored. Plus fluids. ie differential fluid(s), transfer case if 4x4 ( l can't tell in the photo) power steering fluid, engine coolant, maybe a drain and top up of transmission fluid. Possibly even brake fluid. Serpentine belt!
    But I'm thinking of all the above because you might not know what's been done.
    If you can confirm that some of the above has been done, then a few less things for you to think about.
  5. Sep 5, 2019 at 3:20 PM
    Annapolis-Tim
    Tim
    2013 Tayota Tacoma
    Cheers for that. Definitely a good place to start. Here is a photos of the cabin filter.
    Its not a 4x4 unfortunately so no transfer case.
    bshammer0 likes this.
  6. Sep 5, 2019 at 3:24 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Given that, I'd also recommend you pick one of these up b/c with that filter in that condition, your A/C is likely in need of killing the germs / mold and freshening things up. This works really well in my experience
    https://www.amazon.com/gp/product/B07D3B5JTZ/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
  7. Sep 5, 2019 at 3:36 PM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    Bro what
    TheDevilYouLove and 503TRD_22 like this.
  8. Sep 5, 2019 at 3:40 PM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    That is one nasty cabin filter!!!! :eek:
    You can't trust anyone else's previous maintenance regime.
  9. Sep 5, 2019 at 4:07 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I wouldn’t mess with those ac in can products the high and low pressure sides need to be correct. You can make your system function worse then when you started but that just an option. After seeing a filter come out that dirty I would put it on jack stands and inspect everything I could. All fluids, belts hoses. Check out your suspension make sure everything is right and tight. Pretty much all the same stuff you do to your Jeep I would think.
  10. Sep 5, 2019 at 9:07 PM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    Do you know when the last oil change was?
    Seeing that cabin filter and how bad it was, makes me wonder about everthing else.
    Blockhead and TomTwo like this.
  11. Sep 6, 2019 at 5:11 AM
    TheBigKahuna
    TheBigKahuna Well-Known Member
    Those aren't factory fender flares.
    Is it a 5 lug or 6 lug Tacoma?
    If it's a 5 lug that's an aftermarket lifted suspension and, given the condition of the air filter, I'd check that too.
  12. Sep 6, 2019 at 5:18 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Cheap to add to the list, so I'd want spark plugs and PCV valve done, too.
    Grease and inspect play in all the u-joints.
    Inspect play in the front wheel bearings by shaking the s#$% out of each front tire (fore, aft, side to side).
  13. Sep 6, 2019 at 6:14 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Shit, if your cabin filter looks like that, I can only imagine how little the previous owner did to other aspects of maintence!
  14. Sep 6, 2019 at 6:33 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    You have a point, but would be surprised to know how many people in this day and age have no clue their vehicle is equipped with a cabin air filter.
  15. Sep 6, 2019 at 6:40 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Welcome to TW, Nice Truck!!!, If it was mine I would not assume anything has been done. And start by Changing the Engine oil and go from there.
    503TRD_22 likes this.
  16. Sep 6, 2019 at 6:42 AM
    503TRD_22
    503TRD_22 Well-Known Member
    2017 DCLB-OR
    Every mod imaginable.
    welcome to tw :thumbsup:
  17. Sep 6, 2019 at 7:06 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Clean MAF sensor and throttle body
    replace serpentine belt (check idler pulleys while doing this)
    Change coolant and possibly thermostat/upper + lower radiator hose
    Grease all the u joints
    Rear diff fluid
    Fluid film the underside
    Flush power steering fluid
    change spark plugs
    change air filter
    None of the above is difficult or expensive if you do it yourself. Enjoy your ride!
  18. Sep 6, 2019 at 7:08 AM
    TheDevilYouLove
    Marylandistan
    Agreed.
  19. Sep 6, 2019 at 3:17 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    what a sweet little truck, wishing you all the luck in the world with it... ;)
  20. Sep 6, 2019 at 3:28 PM
    Lester Lugnut
    Rick's 2012 likes this.
