Maintenance Before Cross Country Road Trip
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kremtok, Jun 14, 2021.
  1. Jun 14, 2021 at 8:32 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    32k miles? I'd test the battery, check the tire pressure and hit the road
    Kremtok[OP] likes this.
  2. Jun 14, 2021 at 8:35 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I’ve also done quite a few trips on two wheels, one from the Bay Area to Phoenix and back (one day each at 780 miles). Just did a 410 round trip to Philly for cheese steaks!
    It’s a mechanically driven vehicle, sure, shit can go wrong but what is the likelihood?
    Enjoy the trip OP, it’s a fantastic drive and you’re goi g to see a shit ton of stuff that’ll make some good memories!
    Kremtok[OP], Kev250R and HV101 like this.
  3. Jun 14, 2021 at 8:48 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    If you have a jack, lift each wheel up and check for bearing play. That’s one wear-related item that can be exasperated by long miles on the road with heavy gear in the bed or cab. It can go unnoticed in daily driving.
    I wouldn’t bother with changing fluids that are not due, unless it helps from not having to change them on the road when the clock rolls over.
    Not a bad idea to start with a relatively clean air filter, as it will pay for itself in saved fuel.
    Kremtok[OP] and Kev250R like this.
  4. Jun 14, 2021 at 8:52 PM
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    Perhaps drive it as it is now with whatever things you have already done until you reach Canada/US border...then do another oil change, various fluid top offs, air filter changes, tire rotation, and spare tire check on the remaining half of your road trip.
  5. Jun 15, 2021 at 12:12 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Kremtok[QUOTED][OP] likes this.
  6. Jun 15, 2021 at 3:25 AM
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    I’d get a jump box (good thing to have onboard anyway), change the oil, check tire pressure including your spare, check fluid levels and go. Enjoy your trip.
    Kremtok[OP] and Chew like this.
  7. Jun 15, 2021 at 3:47 AM
    gargamel05
    gargamel05 Well-Known Member
    Bay Area,CA ---> Easton,PA
    Just gas and go!!! Safe travel :thumbsup:
  8. Jun 15, 2021 at 3:51 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I haven't driven that far in one shot but I have been way out from any civilization or cell signal for a week + at a time. I will be driving from PA to SD, MT and WY next year.
    Anyway, you would be wasting $ to change a ton of fluids now. If anything, I'd do an oil change before and after (I don't wait for the 10k interval. I do 1 year or 5k). At 32k, a lot of your fluids have a long way to go, even if you are very conservative about it, like me. Check your brakes, tires, filter and fluids (as part of your oil change) and go. Highway cruising is the easiest driving there is on your vehicle, especially if you don't have a ton of weight.
    I'd highly recommend a Noco Genius Boost. It's a small jump box that is also a flashlight and you can charge cell phones from it. A tow rope and med kit that covers both trauma and owies are also good ideas and pretty cheap.
    Most importantly, have fun and make the drive a memorable trip. Plan fun/interesting/scenic stops often and don't rush down the road. Also find a podcast you like.
  9. Jun 15, 2021 at 5:20 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Yeah, I don't think you really don't need to do anything special here other than the standard stuff (check engine bay fluid levels, tire pressure, etc). But I would make sure I had proper emergency gear for a road trip that long (solid first aid kit, tire plug kit, 12v compressor, emergency road side "I gotta shit" kit, drinking water, etc). And snacks, buy plenty of snacks! :)
    PS: buy a set of those FRS handheld radios; one for each vehicle. They have decent range and can really come in handy if you hit an area where there is no cell service.
  10. Jun 15, 2021 at 5:50 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I agree with most. As long as you've kept up on the maintenance schedule and the battery is ok, check the fluid levels, tire pressure, gas up, and go. Any doubts about the battery just load test before you leave. Other than that enjoy the ride and your new found warmth :thumbsup:
  11. Jun 15, 2021 at 5:05 PM
    Kremtok
    Kremtok [OP] Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    Thanks for all of the advice, folks.
    Doesn't seem like there's much of a consensus on doing certain things before leaving vs when we arrive. I could do an oil change and filter change, but I'm not certain it's necessary.
    A few folks mentioned transfer case and differential oil changes. How tough would that be to do in the garage for a guy who knows his way around basic tools? Last time I had to take a vehicle to the shop, it was because I didn't have a pump to fill up the transmission on our Subaru, but other than that I have just about everything that we would need for routine vehicle maintenance.
    I'll reply to a few of you below:
    No, there are no open recalls.
    I'll be driving it when I get to Texas. Well, until my bike is delivered by the movers, then probably not as much...
    As for the 30k service a few folks brought that up. I see that a lot of the fluid changes other than engine oil are recommended for hard use and while the truck has spent its entire life in Alaska, I'm not sure that it's entirely necessary. They haven't been done yet, but I'm considering it. What are your thoughts?
    Oil leaches chemicals from the metals? Interesting theory...
    Thanks for sharing your experience. If any maintenance needed to be done, I'd do it myself in the garage before we hit the road. I'll have most of a week between when the movers leave and when we have to hit the road and I'm bringing enough tools with me to do most routine maintenance, including a battery charger and a 12v air compressor for tires.
    This will be my first INCONUS assignment...and first cross country trip. We sent the kid to be with her grandparents for the summer so it'll just be the old lady and me.
    I hadn't thought about the wheel bearings. Can you point me to a how-to?
  12. Jun 15, 2021 at 5:11 PM
    Stocklocker
    17TRDORDCSBAT
  13. Jun 15, 2021 at 5:14 PM
    Stocklocker
    17TRDORDCSBAT
  14. Jun 15, 2021 at 6:26 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    OK, maybe I'm no expert on oil. But I know how to read and do my own research. Oil changes based on time intervals is still correct.
