Maintenance between 30,000 service?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NightShades, Nov 30, 2011.
  1. Nov 30, 2011 at 6:47 PM
    NightShades
    NightShades [OP] Well-Known Member
    Tallahassee, FL
    05 PreRunner
    Bug Deflector, Bed Extender, Roof Racks
    What maintenace should i be doing between services?
    Besides oil changes what should i be keeping up with?
    how often do you change your coolant?
  2. Nov 30, 2011 at 6:53 PM
    Large
    Large Red
    If you look inside the owners manual there's a pretty comprehensive maintenance guide that covers roughly 90% of your vehicle.
  3. Nov 30, 2011 at 7:00 PM
    NightShades
    Tallahassee, FL
    05 PreRunner
    Whats weird to me, is not much maintenace is required
  4. Nov 30, 2011 at 7:21 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    There is always maintenance- follow the Special Operating Conditions to keep yourself busy...:D
  5. Nov 30, 2011 at 7:22 PM
    NightShades
    Tallahassee, FL
    05 PreRunner
    Is it bad if i leave my center caps off?
  6. Nov 30, 2011 at 8:33 PM
    saugus
    saugus Well-Known Member
    paint the rims black while your there:cool:
