Maintenance/checks before 1400 mile road trip?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDwhite14, Jan 10, 2025.
  1. Jan 10, 2025 at 5:34 AM
    TRDwhite14
    TRDwhite14 [OP] New Member
    2014 DCSB white TRDOR
    About to head out on a 1400 mile round trip. I’ve only had the truck a few months, so not sure of all the history. The carfax shows oil changes, brake services, transmission and transfer case fluid changes, spark plug replacement, tire replacements. What other maintenance items would you look at before taking a long trip? 2014 trdor dcab. Thanks for your input!
  2. Jan 10, 2025 at 5:42 AM
    545 Well-Known Member
    2015 Access Cab
    In my opinion, if you haven’t changed it, you have no idea of its last change.
    So all of the above needs to be checked or changed, plus coolant, brake fluid, grease as needed, etc
    Tatts521 and TRDwhite14[OP] like this.
  3. Jan 10, 2025 at 6:50 AM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    Every spring and fall I set out on a 1600 mile trip from Ft Myers to Boston (or reverse). I KNOW that my brake fluid is good (<3 years). I KNOW that my ATF is good (< 50K miles). I KNOW that my diff fluid is good (<30K miles). I KNOW that my coolant is good (<5 years). Therefore; I verify my tire pressure, grease my driveshaft, verify that I am not due for an oil change in the next 1600 miles, fill the tank and hit the road.
    With an unknown truck, I would change everything above before I set out.
    Tatts521 likes this.
  4. Jan 10, 2025 at 11:26 AM
    TacoTuesday1
    SD CA
    depends on when. Carfax is not worth anything.
    this is why inspections are done. Inspect it.
    that and maybe anything you suspect on being on its last legs.
    For example I did my front belt drive system. Rather have done it now than to have something snap and break during a drive.
    It’s old and has miles. So do the components. And some things are wear items with typical finite life spans.
    is it a thing to change a frame at 10/100? No.
    Is it a thing to change front belt drive components before 200k? Absolutely.
    especially if preparing to go on a long drive like that.
  5. Jan 10, 2025 at 11:30 AM
    avery0829
    avery0829 Well-Known Member
    Western Washington
    2005 Tacoma DCLB Sport
    Bilstein 5100, Trail edition wheels, 265/70/17 Falkens
    I'd check the drivebelt above all else. I try to think of components that would require a tow truck.
  6. Jan 10, 2025 at 12:00 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    How many miles on truck? Definitely check pad wear on brakes. If going into really cold weather, maybe replace battery if it is less than 4 years old, or do a load test on it.
  7. Jan 10, 2025 at 12:11 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    at 200k+ miles, i went on a big trip to Outerbanks after doing front end suspension replacement, brakes and new tires.
    Changes my plugs a year or so later that were factory.
    Didnt even look at anything else and was fine for next 100k
