Maintenance "codes"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shwaa, Dec 20, 2014.
  1. Dec 20, 2014 at 10:01 AM
    Shwaa
    Shwaa [OP] Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    Stupid question, but how can you tell if your truck throws a code? i.e. if someone says "my truck shows the 1234 code", where do you see that? On the dash? I know the check-engine light is on the dash, but I have no idea where the codes show up.
  2. Dec 20, 2014 at 10:03 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    With a scan tool. Plug it in and it will read the codes from the ecu.
  3. Dec 20, 2014 at 10:07 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    The truck wont tell you the codes... you have to plug in a seperate code reading tool into the OBDII port
  4. Dec 20, 2014 at 10:09 AM
    Shwaa
    Bay Area, CA
    ahhh gotcha. thanks guys
