Maintenance due soon light
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cypresstrd16, Jan 26, 2018.
  1. Jan 26, 2018 at 3:20 PM
    cypresstrd16
    cypresstrd16 [OP] Member
    2016 trd sport 4x4
    i have a maintenance required soon light that would turn on once in awhile for the past few days, but when I press on it, it doesn't tell me what is needed and disappears.
    Is this supposed to happen when it first reminds you and stays on when maintenance is really needed? Or do I have a problem?
    Any info is appreciated!
    Thanks
  2. Jan 26, 2018 at 3:22 PM
    eurowner
    eurowner Duke Sky
    Scoty
    What is your mileage?
    Vbpiper likes this.
  3. Jan 26, 2018 at 3:23 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    If it's like the 2nd gen it just pops on every 5k miles from the time it was last reset. Just a reminder message
    Vbpiper likes this.
  4. Jan 26, 2018 at 3:28 PM
    cypresstrd16
    2016 trd sport 4x4
    I got the car with 11k miles has 16k now, just wondering why the light doesn't stay on.
  5. Jan 26, 2018 at 3:30 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    It will stay on when it says Maintenance Required.
  6. Jan 26, 2018 at 3:48 PM
    A/C Mech
    A/C Mech Well-Known Member
    Alan
    LBC
    2017 TRD OFF-ROAD
    Bought my truck with 9,100 miles on it. They just changed the oil. I just hit 14,000miles. It just came on again. I think Toyota wants you to change it at 5,000. I just reset it. I’m changing mine at 10,000 with Mobil 1.
    To reset just hold odometer in while pushing start button without pressing brake. I think you’ll see 3 or 4 dashes that blink and then disappear. Then you can let go...
  7. Jan 26, 2018 at 3:53 PM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    It comes on at start up at about 4500 miles since last reset and will stay on at 5000 miles. Its just a reminder to get maintenance like rotations and oil changes but it can be reset at anytime and just start counting the miles over. This lines up with your current mileage. You don't NEED any services at 15k other than a tire rotation. Check the owners manual for maintenance schedule. If the check engine light isn't on, its not a problem.
    shakerhood likes this.
  8. Jan 26, 2018 at 3:53 PM
    jrain904
    jrain904 Well-Known Member
    5000 mile reminder is most likely for tire rotation, not oil.
    Lt. Dangle and A/C Mech[QUOTED] like this.
  9. Jan 26, 2018 at 3:54 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It comes on every 5K since the last reset. Odd numbers is check fluids and tire rotation. Even numbers is same + oil and filter change.
    cypresstrd16[OP] and A/C Mech like this.
  10. Jan 26, 2018 at 3:55 PM
    EdgeCrusher
    Chicagoland
    There are maintenance recommendations every 5k miles with oil change being every 10k.
    A/C Mech[QUOTED] likes this.
  11. Jan 26, 2018 at 4:02 PM
    cypresstrd16
    2016 trd sport 4x4
    Thanks guys!
  12. Apr 10, 2018 at 7:55 AM
    ChasVS
    ChasVS Well-Known Member
    2017 Tacoma ACLB TRD Off Road
    I'm about to bring my Taco in for it's 15K Service. Looked for my Wheel lock key to make sure it was available only to find out it's still in the SEALED plastic bag it came in. It's not been used and I brought to TACO in for the 5K and 10K Services! Do Dealers have a Universal Key of their own so mine isn't used? If not, my tires haven't been rotated since new and I'm pissed!
