Maintenance For Toytec Ult Kit and TC UCAs???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmed99, Dec 21, 2010.
  1. Dec 21, 2010 at 4:33 PM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    I tried to search but couldn't find anything...used toytec and maintenance as keywords....
    I put on the Toytec ultimate kit with AAL several months ago along with Total Chaos UCAs. When I installed all of this I greased the zerks and sprayed some marine lubricant on the uniball. That was several months ago...
    -What maintenance is required for this setup?
    -Do I need to regrease the zerks and uniball?
    -If so, how often?
    Is there anything else I need to do to maintain this setup? re-torque bolts, etc
    Thanks for all your help! :D
  2. Dec 21, 2010 at 4:37 PM
    jandrews
    '09 FourDubDee TRD OR
    Give the zerks a little grease every now and again...just one or two pumps per zerk per oil change should be fine (do your driveshafts while you have the grease gun out).
    The uniballs I would hit with lube more often...I usually do mine after each wash...remember, teflon based lube on the uniballs...
    If you wheel regularly, re-torquing your suspension every 6 months or so is a good idea.
  3. Dec 21, 2010 at 4:40 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    ^x2 and don't forget to throughly clean the uniball before using the dry teflon.
    As for the rear, if it squeaks you could put some grease between the anti friction pads or some use bicycle tubes.
  4. Dec 21, 2010 at 4:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Being as you have a Prerunner, you dont have grease zerks on your drive shaft. But grease the UCA's based on use. If you dont off road often, grease them once every few months, or so. I grease mine every 6 months, or 15k miles. The uniball shouldnt need any lube at all. Using anything but a Dry lube can result in the cup wearing out prematurely.
  5. Dec 21, 2010 at 4:49 PM
    jmed99
    SC
    Thanks guys! I dont go off road at all really.
    -So I'll grease the zerks once every 6 months, but how many pumps per zerk to maintain?
    -So I'll never need to use the dry lube on the uniballs again?
    Thanks again!
  6. Dec 21, 2010 at 4:55 PM
    Jason'sLawnCare
    haha. No. He's saying don't use lube as in from the grease gun because it attracts dirt and the dirt will wear the ball or cup faster. Use a dry lube. Dupont Dry Teflon is the only one I know of and it's available at Lowes.
    Wheelers sells some dry lube to
  7. Dec 21, 2010 at 4:55 PM
    jandrews
    Not a high-stress application like u-joints, so just enough to keep it fresh...1 or 2 pumps per zerk.
    Don't overgrease. If you see the urethane bushings "mushrooming" out, that's too much. Stick the head of the zerk with a paperclip if this happens so that excess grease can release and ease the pressure.
    IIRC TC says to keep them lubed with a dry lube. I like to wash thoroughly (glancing spray of water with some mild pressure) and then hit them with a coat of DuPont Teflon spray lube, which sets up as a dry wax. This wax catches most of the shit that would otherwise go into the uniball and then gets blasted off at the next wash. May help keep contamination down.
  8. Dec 21, 2010 at 4:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What they said ^^^^ I spray some dry lube on mine once a year.....if that....
  9. Dec 21, 2010 at 5:00 PM
    Jason'sLawnCare
    That's what I do. Hit them up with the hose then use a clean paper towel because the hose doesn't get everything.
    The dry teflon doesn't "hold" the dirt it doesn't let the dirt stick to it.
  10. Dec 21, 2010 at 5:01 PM
    jmed99
    SC
    Ok! Thanks for all the help!
  11. Dec 21, 2010 at 5:02 PM
    jandrews
    If teflon cookware has taught us anything, something will manage to stick to everything. PLus, by nature of the shape of the uniball, shit is going to pile up on top of it.
    I agree with you though, it's nothing like oil based lubes, and not porous like graphite lubes. Definitely the best dry lube I've found yet.
  12. Dec 21, 2010 at 5:06 PM
    Jason'sLawnCare
    or maybe the key word was let:p it may not let the dirt stick but some dirt is persistent.
  13. Dec 21, 2010 at 5:09 PM
    jandrews
    Dirt rape.
  14. Jan 18, 2011 at 6:41 PM
    jandrews
    I'd like to amend my recommendations. I ran my UCA bushings dry after about 2 months with pretty regular wheeling (1 trip every ~2 weeks). If you flex the truck out a lot, grease more often...say a couple pumps per zerk every 3 months.
