Maintenance help...wont start.
Discussion in '1st Gen. Tacomas (1995-2004)' started by DTaCo, Nov 27, 2009.
  1. Nov 27, 2009 at 6:05 PM
    DTaCo
    DTaCo [OP] Active Member
    Dylan
    Minnesota
    2003 Tacoma manual 4x4 V6
    6" Drop Bracket Suspension Lift with coil spacers and a 1" body lift. Trailmaster add-a-leaf in in the back with a 3" block.
    Today I changed the plugs, wires, fuel filter, PCV valve, and air filter. When I put it all back together the fuel filter wasn't on tight and fuel shot out of it. Now when I try to start it, it just starts and stops. I tried disconnecting the battery and also just turning the key to ACC a bunch of times to get the filter filled up, but it still just starts for about 3 seconds and then stops. Is this a fuel related problem or a spark plug wire connection problem or something else. Let me know your thoughts I dont want to have to bring it to the dealer. Thanks
  2. Nov 27, 2009 at 6:35 PM
    98tacoma27
    Ben
    Not Beech Creek
    What plugs and did you gap them?
  3. Nov 27, 2009 at 6:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Along with what 98tacoma asked:
    it may take a few tries to get the truck running after the filter is changed. Odds are, when the filter wasnt tight, the fuel injectors may have lost their prime. Pull the EFI fuse, and let it sit for about 10 mins. then install the fuse again, and try to start it.
  4. Nov 27, 2009 at 7:28 PM
    DTaCo
    Dylan
    Minnesota
    The plugs were NGK 3967 with the head coming from two sides, I wasnt sure how to gap them so I didnt. I also let it sit for over an hour and tried it with no luck. I turned it over at least 10 times each time letting the fuel pump prime a little bit before turning the key. Is there any sort of safety device that would not allow me to start it after having fuel shoot out of the fuel filter?
  5. Nov 27, 2009 at 7:31 PM
    DTaCo
    Dylan
    Minnesota
  6. Nov 27, 2009 at 8:08 PM
    DTaCo
    Dylan
    Minnesota
    Just tried pulling the EFI fuse and then starting it and had the same problem. Starts and runs for about 2 seconds and then stops.
  7. Nov 27, 2009 at 8:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There is no cut off that Im aware of.....Im still wrapping my brain around this.
  8. Nov 27, 2009 at 8:12 PM
    DTaCo
    Dylan
    Minnesota
    I'm going to try taking the wires back out tomorrow and putting them back in to make sure they are fully secure. If a plug wire isnt all the way on would it cause this problem or would it just run like crap?
  9. Nov 27, 2009 at 8:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It should run. I sent a PM with this link to member kevhogaz, as he is a Toyota Tech., and I think he may be able to shed some light on this.
  10. Nov 27, 2009 at 8:17 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    just for shits and giggles, but you did notice there is a direction of flow on the fuel filter right?
  11. Nov 27, 2009 at 8:17 PM
    DTaCo
    Dylan
    Minnesota
    Thanks, I feel like it is probably something simple (I hope) as long as I get it going by Monday I will be fine.
  12. Nov 27, 2009 at 8:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    doh!
  13. Nov 27, 2009 at 8:18 PM
    DTaCo
    Dylan
    Minnesota
    Yeah I checked that and rechecked it, I am pretty sure it can only go on one way.
  14. Nov 28, 2009 at 7:49 AM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    All right, let's see what we got here.
    Your truck starts then dies, right? So we have fuel, but only momentarily. Make sure you didn't unplug the fuel pressure regulator, when you did the left hand plugs. It's got a vacuum line going in to it, at the end of the fuel rail, in the back.
    Second, make sure you didn't kink the fuel line that runs up the side of the motor. It's the spiral wrapped flex line that comes up from the frame, and goes to the fuel rail. Almost impossibe to do, but it doesn't hurt to check.
    Third, take a look around everything you worked on, and make sure everything is where it's supposed to be.
    I'd guess it's something simple, since the truck ran before you worked on it. Like someone else mentioned, double check the orientation of the fuel filter. I'm pretty sure they only go on one way, but anything is possible.
  15. Nov 28, 2009 at 12:21 PM
    DTaCo
    Dylan
    Minnesota
    I tried putting the old fuel filter back on and took out the plugs and wires and put them back on as well. Still have the same problem. When I first started it the fuel filter wasnt on correctly and a bunch of fuel shot out of the fuel lines around the fuel filter. Is there any sort of fuel cut off or any other safety thing that it could be?
  16. Nov 28, 2009 at 12:39 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    firing order on the wire replacement. :shrug: or maybe if there is one of those bleeder valves for the fuel pressure. idk this maybe way off but id thought id make a suggestion.. you'll get it going! :)
  17. Nov 28, 2009 at 12:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No fuel shut off that I know of.....
  18. Nov 28, 2009 at 1:48 PM
    DTaCo
    Dylan
    Minnesota
    Right now I have the spark plug wires set up like this:
    Firewall
    Left Back --------- Right Front
    Left Middle -------- Right Back
    Left Front -------- Right Middle
    Radiator
    I think this is correct but there isnt a diagram in the haynes manual and when I called the dealership they gave no advice. If my diagram doesnt make sense let me know.
  19. Nov 28, 2009 at 1:52 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    have someone turn on the key and see if you can hear the fuel pump whirring in the tank?
    Check all igniton fuses to make sure nothing is blown. By the sounds of it(runs for a sec, then dies out) that your wiring is wrong. Check the wires themselves and make sure there good and tight.
  20. Nov 28, 2009 at 1:54 PM
    98tacoma27
    Ben
    Not Beech Creek
    ^^^Firing order
