Maintenance Interval For Front Differential and Transfer Case?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hotajax, Nov 10, 2021.
  1. Nov 10, 2021 at 2:48 PM
    hotajax
    hotajax [OP] Well-Known Member
    09 TRD Off Road
    Been all over my maintenance guide that came with the truck. Unable to find any info on mileage between gear oil changes for the front diff and xfer case (Rear diff is due every 30K because of the LSD feature). The only reference to gear oil in front diff and xfer case is to "inspect" the oil. Nothing about a change. How do you gents with 4 x 4's handle this? Thanks.
  2. Nov 10, 2021 at 2:59 PM
    hotajax
    09 TRD Off Road
    Seems like the last time I changed out the goop up front, it was still in pristine condition. The rear diff was a completely different story - it stunk to high heaven.
    PS: Seems like a pretty covenient document. Where'd you find this?
    HillJackJDS likes this.
  3. Nov 10, 2021 at 3:03 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    front diff and tcase for me get changed every other time the rear diff does.
    I changed rear diff at 30k intervals up till 120k, this most recent change the rear diff and front/tcase came out looking good, so now im going 40k intervals on the rear and 80k on front/tcase.
    Also OP. if this is on your 09 you have a standard open diff with a simulated lsd via brakes. 08 was the last year of the mechanical LSD.
  4. Nov 10, 2021 at 3:06 PM
    hotajax
    09 TRD Off Road
    ND4: Yes, you are right. I have an 09. So does that mean I do not need to change out the lube at every 30K?
  5. Nov 10, 2021 at 3:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The biggest thing with the front is to do it soon(er) than later.
    It’s a 10mm Allen. It’s known to get stuck and strip.
    Before you do anything, break the FILL plug loose.
    Then buy one of these, (You can find them at most auto parts stores)
    https://www.amazon.com/Lisle-29200-Hand-Impact-Tool/
    You’ll also want 10mm socket Allen.
    Forget using a standard Allen wrench. That’s asking for trouble.
    Then get out the hammer, SMMMAAACK!
    Replace the OE drain plug with this one
    https://www.tacomaworld.com/threads/front-diff-drain-plug-alternate-oem-part.604989/
    https://www.lexuspartsnow.com/parts/lexus-plug-for-front-differential-drain~90341-24016.html
    Biscuits, wi_taco and Dm93 like this.
  6. Nov 13, 2021 at 10:58 PM
    HillJackJDS
    HillJackJDS Well-Known Member
    Dale
    2008 Tacoma 4WD
    Great Chart! I need to see if I have the equivalent somewhere for my 2008 2.7L 4WD 2-door Base!
