Maintenance items for 103,000 miles
Discussion in 'Technical Chat' started by Gaunt596, Aug 13, 2013.
  1. Aug 13, 2013 at 10:09 AM
    Gaunt596
    Gaunt596 [OP] Well-Known Member
    Matthew
    Central Maryland
    Okay, soo, i bought my taco with 100k on the ODO, and assuming that the truck has conventional oil, i am going to change it once it hits 103k, witch should happen in a week or two. going by the info i gatherd from this site and assuming the previous owner has done nothing other than oil changes(the filter that is on it isn't a Toyota filter), i have put together this list of items that i am changing out/replacing once i hit 103k
    Engine oil- switch to synthetic
    Oil filter
    Power steering fluid- drain and refill
    Brake fluid- drain and refill
    Front and rear diff fluid- drain and refill
    Transmission fluid - flush and refill
    transfer case oil- drain and refill
    Engine air filter- replace
    cabin air filter- replace with washable one
    spark plugs- replace all plugs
    grease driveshaft
    check/replace front and rear brake pads if needed
    switch out valve stems(front left tire is leaking at the stem)
    Water Pump- Replace
    Engine coolant- Drain/flush and refill
    check serpentine belt and replace if needed
    please let me know if im missing anything, and i know this seems like alot, but i want this truck to last, especially since its my first:p
  2. Aug 23, 2013 at 10:38 AM
    Manwithoutaplan
    ID
    what do you do for maintenance on your waterpump??
  3. Aug 23, 2013 at 10:43 AM
    Manwithoutaplan
    ID
    Are trucks don't have external fuel correct???
    I heard the fuel filter is in the gas tank is this correct?
  4. Aug 23, 2013 at 10:55 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I'm almost at 100k. I gotta do all this maintenance
  5. Aug 23, 2013 at 10:57 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    im at 94K, This list will be handy
  6. Aug 23, 2013 at 11:07 AM
    Gaunt596
    Matthew
    Central Maryland
    Your welcome :)
  7. Aug 23, 2013 at 11:08 AM
    Taco Dan
    Dan
    Tuscaloosa, AL
    is it really necessary to replace the water pump?
  8. Aug 23, 2013 at 11:09 AM
    obzerver
    obzerver Well-Known Member
    Justin
    Surrey, BC
    09 SR5 TRD
    Grillcraft grill, 20" LED Light bar, 17" MB TKO wheels, 265/70R17 Cooper ATPs, Uniden PRO520XL CB, Pioneer AVH-P2400BT
    sub'd, I'll be needing to do all this soon too.
  9. Aug 23, 2013 at 11:11 AM
    WThomas1250
    WThomas1250 Well-Known Member
    I don't think it's completely necessary unless it's leaking or if the vehicle has a timing belt
  10. Aug 23, 2013 at 11:18 AM
    Gaunt596
    Matthew
    Central Maryland
    yes and no. my truck(thank god) has nothing wrong with it mechanically at this point. however, looking at the dealer service stuff that came with it (previous owner left all the dealer service coupon stuff in the truck, as well as his name, phone number and address on a sticker on one of the books lol) you should replace the water pump at 60k.
