Maintenance light not reseting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ant1-Hero, Jan 22, 2018.
  1. Jan 22, 2018 at 9:21 AM
    Ant1-Hero
    Ant1-Hero [OP] Well-Known Member
    2013 Tacoma TRD OFFROAD
    Hello,
    I have a 2013 Tacoma and just did an oil change ahead of schedule. I have followed every guide and video on the subject to reset the maintenance count down.
    I turn key to off, set trip to A, kept odometer reset button pressed down, and turn key to on. Nothing happens... no count down, no change. Just sits there.
    I tried several combinations, took key out, held for several seconds. Still nothing.
    Any Ideas?
  2. Jan 22, 2018 at 9:22 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Try odometer and trip A. Stick the key in, hold down the reset button. To key to key on engine off and it should take. Do not release the reset button while turning the key
  3. Jan 22, 2018 at 9:23 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I think you have to go back to odometer
    TacoSupremeo and TacoCat like this.
  4. Jan 22, 2018 at 9:25 AM
    toysrgood
    toysrgood Well-Known Member
    SC
    2011 4x4 Reg Cab
    tcjacado and TacoCat like this.
  5. Jan 22, 2018 at 9:25 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    On my 2010 I had to be on odo as well. Put it on odo, hold the button down, keep holding the button down while turning the key to the "on" position (don't start it). A series of dashes will flash. When it does, they will go down to no dashes left. Keep holding till it flashes the zeros, that means the maintenance interval is reset.
  6. Jan 22, 2018 at 12:35 PM
    Ant1-Hero
    1. Turn the ignition key to the "OFF" position with the odometer reading shown (For details, see "Odometer and two trip meters" on page 143 in this Section.) (Note 2: 2011 + models require using the TRIP A reading)
  7. Jan 22, 2018 at 12:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    You can't set to A with the key off.
    Procedure:
    Set to A with key on/truck running
    Turn key to off/lock position
    While pressing the ODO/Trip button, turn the key to the on position
    Hold ODO/trip button until display is 000000
    This is from page 323 of my '13 owners manual. Works for me.
  8. Jan 22, 2018 at 1:03 PM
    redcon
    redcon Well-Known Member
    Dave
    Southern PA
    2012 AC 4x4 Base 2.7L/5MT
    Yes. Just did the reset on Saturday after Oil/Filter change, and worked like a charm.
  9. Jan 22, 2018 at 1:22 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Just went out and tried mine ,Bill has got it right, tried it on odo first and it didn't reset.
  10. Jan 22, 2018 at 1:38 PM
    Ant1-Hero
    I just tried it again going step by step, it still doesnt do anything. The only difference is when i turn the key to the off position, when i press the reset button, it turns the display on...
  11. Jan 22, 2018 at 2:22 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Did you follow the steps Clearwater Bill posted exactly? This is how I reset the light on my 2012.
  12. Jan 22, 2018 at 2:29 PM
    Ant1-Hero
    Yes it is, I'm pretty mechanically inclined so I'm not sure what I am missing. Do your trucks odometer turn on while key is in off position if you press the reset button? Might be related to the remote start in my truck or something.
  13. Jan 22, 2018 at 2:49 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Use electrical tape.
  14. Jan 22, 2018 at 6:55 PM
    Tacosail
    Jerry
    '13 white ACLB
    Try turning the key on without starting, then cycle the odometer all the way around to trip A, turn key off. Then, push in and hold the button in, then turn the key to on. The odometer should show _ _ _ _ _ . The lines should start blinking, with one line disappearing with each blink. When all the lines are gone it should come up ooooo, then blink and show whatever mileage you had on trip a when you started the reset, and the maintenance light should go out.
  15. Jan 22, 2018 at 7:27 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If this doesn't work I see a trip to the dealer in order.
  16. Jan 23, 2018 at 3:50 AM
    Ant1-Hero
    I just have one question, does your odometer illuminate when the key in the the off position when you push the odometer reset button, mine shows the odometer readings when the key is in the off position. If I push mine in, I can cycle through odometer/A/B with the truck off. If I open the door, then the display shuts off.
    Also I am setting the truck the ON position (two clicks forward) and not ACC (1 click).
    I have tried a few different ways, I'll have to stop by the dealership, I think my remote starter is doing something
  17. Jan 23, 2018 at 7:04 AM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    My od turns on when I press the button with no key in the vehicle.
  18. Jan 23, 2018 at 7:06 AM
    Ant1-Hero
    Then I have no idea what the issue is, i have done all of these steps a dozen times. stick key in to On position, set OD to A Trip, turn key off, press in OD reset button, Turn key to on. Display just shows Trip A 0.0
  19. Jan 23, 2018 at 7:14 AM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Are you holding the reset button down when you turn the key back to on or just pressing it? You have to hold it down.
    Where are you located? Maybe someone local can give it a shot and save you a trip to the dealer?
  20. Jan 23, 2018 at 7:19 AM
    Ant1-Hero
    I am holding it down. I've watched several videos and from what I can tell, I am doing the exact same thing. My maintenance light is not on, does this only work when the light is on, or can someone do it at anytime to reset the counter based on when the oil change was done? I'm in Halifax, Nova Scotia. Canada
