Maintenance light won’t go out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The90forts, Mar 15, 2025.
  1. Mar 15, 2025 at 5:57 PM
    The90forts
    The90forts [OP] Member
    2011 Silver Tacoma TRD Sport
    Hi all, I just got a 2011 Tacoma with 120k on it. The maintenance light is always on and I’ve tried to reset it the way it says in the manual, and it’s not resetting. It’s solid and not flashing so it’s been on for a while I’m guessing. Is this a common problem for these trucks? Is the only way to fix it replacing the cluster? It’s not a big problem, I just hate to see it. Thank you for any help. Let me know if more information is needed
  2. Mar 15, 2025 at 5:59 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    How are you doing it?
  3. Mar 15, 2025 at 6:07 PM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    When you try resetting it are you seeing the decreasing number of blinking dashes on the odometer?
  4. Mar 15, 2025 at 6:27 PM
    Bishop84
    Bishop84 Well-Known Member
    Without looking I try it 2 different ways.
    Set to Odo, key off, then hold reset on the cluster, then key on for 5-10 seconds.
    Otherwise Trip A, key off, hold reset, key on 5-10.
    super_white likes this.
  5. Mar 16, 2025 at 7:40 AM
    The90forts
    I have tried both of these ways. I don’t get the count down on the odo nor the zeros.
  6. Mar 16, 2025 at 7:56 AM
    Pnwadventure
    Pnwadventure Well-Known Member
    Kirkland wa
    2006 white access
    While vehicle is running set to odo. Turn key to off position. Hold down odo toggle Button start vehicle while keeping toggle button depressed until reset
  7. Mar 16, 2025 at 7:58 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    I always pull what little hair I have left out trying to remember EXACTLY what I did the last time. And that goes for both my rides that have resets. The old ride, mark the miles down and go.
    Williston likes this.
  8. Mar 16, 2025 at 8:34 AM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    From page 403 in the 2014 Owner's Manual:
    -When the engine is running switch the display to Trip Meter A.
    -Turn the engine switch to the LOCK position.
    -While pressing the ODO/TRIP button, turn the engine switch to the ON position:
    -Continue to press and hold the button until the odometer displays "000000"
    -If the display fails to reset, the light will continue flashing.
    Note: The above is directly from the owner's manual however
    there is no hint or mention of the rolling count-down/re-set thing it does
    while holding the button down. :evil: Go figure. :facepalm:
  9. Mar 16, 2025 at 9:12 AM
    The90forts
    I just attempted this while it is running. Is it possible my cluster is fudged? Thanks for all the help
  10. Mar 16, 2025 at 9:33 AM
    Williston
    New England
    I just checked it again for Typos and it looks good. FWIW, I almost never get it to work on the first attempt. Maybe a timing issue if too much time goes by between the steps? Dunno. But the dealer almost never resets the light on my truck when I have them do an oil change. Probably aggravates them too and time is money.
  11. Mar 16, 2025 at 9:39 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Don't start the truck...turn the key on while holding the reset switch.
    WNYTACOMA and Strictlytoyz like this.
  12. Mar 16, 2025 at 9:48 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Dont forget to stick your tongue out & have 1 foot out of the vehicle while doing so or it wont work....o_O:frusty:
  13. Mar 16, 2025 at 9:53 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Isn’t the process for a 2.0 gen (2005-2011) different than the 2.5 gen (2012-2015)?
    OP you’re checking the manual for a 2011 or earlier, right? Cause what people have been posting are what I do for my 2015.
  14. Mar 16, 2025 at 10:10 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    I got tired of repeatedly having to turn the maintenance light off so I just leave it on. I know it means nothing to me. Part of happiness is not sweating the small stuff
  15. Mar 16, 2025 at 10:36 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The year it changed from Odometer to Trip Meter 1 was 2011. The difference being the RED Cluster Gauge or the WHITE Cluster Gauge.
    IF you have the Combination meter with a Red color use the Odometer to reset.
    IF you have the Combination meter with a White color use the Trip Meter 1 to reset.
    If neither of these work you have an issue.
    Williston and JasonLee[QUOTED] like this.
  16. Mar 16, 2025 at 10:57 AM
    Williston
    New England
    Makes sense: Right around the time of the 2nd Gen refresh.
    Jimmyh likes this.
  17. Mar 18, 2025 at 12:18 PM
    The90forts
    pretty sure I have an issue lol. I resetting both ways. In my factory owners manual that’s from 2011, it says to set it to the odometer. It still doesn’t reset. I’ve tried to reset it with the trips too and it doesn’t work. I’ve tried it key in the run position both with engine on and off. What could be the cause?
  18. Mar 18, 2025 at 12:27 PM
    The90forts
    I should also add. There was an aftermarket remote start kit added. Is it possible this may be causing problems like the installer messing up the wiring or something?
    is it possible I would be able to reset it with my obd scanner?
  19. Mar 19, 2025 at 12:56 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I would guess something in the combination meter, BUT that is only a guess based on the fact that the lamp is based purely on mileage and all the controls for it is in the combination meter. Plus looking at the print for the combination meter it appears that the idiot lamp for the maintenance required is controlled completely by the logic in the combination meter.
    I highly doubt that the remote start would have anything to do with the Maintenance Light.
  20. Mar 19, 2025 at 5:39 PM
    wdunnlee
    wdunnlee Well-Known Member
    Will
    Tidewater VA
    2010 Timberland Mica 4x4
    If you take some electrical tape and cut it in a 15MM x 15MM square, it should perfectly block it.
    Out of sight out of mind:crapstorm:
    Seriously though…
    BTO likes this.
