Maintenance Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomacanada, Jan 27, 2012.
  1. Jan 27, 2012 at 9:57 AM
    tacomacanada
    tacomacanada [OP] New Member
    08 Tacoma 4X4
    Does anyone know the reasons that will cause the Maint Reqd light to come on other than for the 5000mile oil change? Does it come on at other intervals for other oils that need to be changed (diffs, transmission, transfer case, etc.)? My light came on and it was before the scheduled oil change. I do not want to just reset it without addressing the problem (i know how to reset).
  2. Jan 27, 2012 at 9:59 AM
    Brunes
    Brunes abides.
    Rotorhead
    Just oil. How much before the scheduled change did it light??
  3. Jan 27, 2012 at 10:08 AM
    tacomacanada
    08 Tacoma 4X4
    it came on in about 3000miles
  4. Mar 17, 2012 at 10:52 AM
    CK4500
    CK4500 Well-Known Member
    Red Deer, AB, Canada
    2011 Reg Cab
    At 3000 miles, that is your oil change reminder. I don't think its set up to go 5000 miles betweem oil changes. In Canada, 5000 km between changes, yes.
  5. Mar 17, 2012 at 1:51 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    2010 4 X 2 Regular Cab
    Chrome exhaust tip
    The maintenance required light comes on in 5000 miles from the last time it was reset, regardless of what type of maintenance procedure (if any) was performed. You can safely reset it now, but keep track of the mileage 'till your next oil change is due, then reset it again after.
  6. Mar 17, 2012 at 5:40 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Read the manual. That light can be set for different intervals up to 5000 miles.
  7. Mar 17, 2012 at 5:50 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    4500 miles the light will flash for a short time after startup.
    5000 miles it comes on solid.
    Toyota used to recommend 5000 mile intervals for "severe service" and 7500 miles for "normal service".
    That was the OM recommendation on my '03 Tundra.
    When they added the maintenance light, on a vehicle-by-vehicle basis, they dropped the 7500 mile interval and just put everyone on 5000 whether it needs it or not.
    It's stupid, and an example of Toyota's cost-cutting over the last 20 years.
    Even the General Motors OLM has some intelligence behind it, calculating not only mileage, but engine/coolant/air temperature, engine RPM, fuel consumption, engine load, etc... In short, if the GM OLM says to change at 4000, you NEED to change at 4000. If it doesn't say to change until 8000, you don't need to change until 8000.
    My '06 Duramax would recommend changes anywhere from 8k to 12k. Since I was running synthetic and a premium filter (no Delco/Fram/Supertech shit), I was comfortable following the longer interval.
    3000 mile oil changes are not only a waste of money, but a waste of natural resources. Modern vehicles do not need to be changed at 3,000 miles.
  8. Mar 17, 2012 at 6:37 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Tacomacanada, you must have a US tacoma, the canadian versions don't have a maintenance light.
  9. Mar 17, 2012 at 7:12 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    from my understanding they can be set for different intervals, when you reset them there are those 00000 and I think the less 000 mean more mileage til it goes on
  10. Mar 18, 2012 at 9:57 AM
    dfxdig
    dfxdig Well-Known Member
    myrtle beach, sc
    06 trd offroad sr5
    k&n intake, custom bed rack
    no intervals, when reset, the cpu will start from zero miles and log them for 4500 miles, then blink and come on at 5000 miles.
    why the hassle? use mobil 1 15,000 mile oil and not worry about it.
  11. Mar 18, 2012 at 10:16 AM
    nammer
    Nam
    Bradenton, Florida
    yea i was trying to find the thread where I read that, but can't seem to, it looks like you're right, i've only set mine back to the 5000 mark personally
  12. Mar 24, 2012 at 2:51 AM
    jeratbp
    jeratbp Well-Known Member
    Jeremy
    Norfolk, VA
    '05 4Runner Sport V8
    i bought my truck used, and don't have the manual. i will try resetting it, since they changed the oil when I bought it 3 weeks ago.
    EDIT - thanks for the info, no more Maint light. Now I just need to find the vehicle manual online.
