Maintenance Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thomasr1950, Nov 9, 2013.
  1. Nov 9, 2013 at 5:10 PM
    thomasr1950
    thomasr1950 [OP] 19 Tacoma TRD Off Road
    central us
    My 09 Tacoma V6 Maintenance light has come on. I checked the oil, it was low so I added about a 1/2. The light is still on. I had the oil changed back in the summer. I have 32,000 mi on it & all maintenance done by a Toyota Authorized Dealer. Last oil change was back in the summer. Is there a sensor or something that perhaps didn't get reset? This light has never come on before, I don't drive the hell out of my truck. The 3yr service was done last Dec. the only thing not done was plug replacement. What is the reason for the light to come on?
    Thanks,
    Tom
  2. Nov 9, 2013 at 5:19 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Could you be due for maintenance just by the light being on(by the computer)? That's the only thing that I can think of. If it wasn't reset then it would have stayed on since the summer.
  3. Nov 9, 2013 at 5:20 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    What mileage did you have the maintenance done?
  4. Nov 9, 2013 at 5:27 PM
    thomasr1950
    central us
    Thanks for your reply. I think about 28,000 mi.
  5. Nov 9, 2013 at 5:29 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    What maintenance light ?
  6. Nov 9, 2013 at 5:30 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    That maintenance light will come on every 5000 miles to let you know it is time for an oil change. Your owner's manual will tell you how to reset it for another 5K.
  7. Nov 9, 2013 at 5:31 PM
    OZ-T
    Peter North
    British Columbia
    I don't have a maintenance light
  8. Nov 9, 2013 at 5:33 PM
    thomasr1950
    central us
    Maintenance Required is a yellowish light on the bottom of the speedometer on my 09Tacoma.
  9. Nov 9, 2013 at 5:35 PM
    nfs257
    DFW
    She gone
    you have went 28,000 miles on 1 oil change?!!?!?
  10. Nov 9, 2013 at 5:36 PM
    OZ-T
    Peter North
    British Columbia
    I was kinda being sarcastic , the Canadian trucks don't have them
  11. Nov 9, 2013 at 5:43 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    OP. Sounds like you've put 5k miles on the truck since your last scheduled maintenance. Did the light start flashing only upon start up, and then eventually remain on? That's normal. It's reminding you that every 5k you need to change your oil, not just add a quart.
  12. Nov 9, 2013 at 5:44 PM
    thomasr1950
    central us
    Oil is changed every 6 months, required maintenance by Toyota has been done on a scheduled basis by a Toyota Dealer. Toyota has a record of all work done on the truck. I only have 32,000 mi & am the original owner, only driven by me & my wife.
  13. Nov 9, 2013 at 5:46 PM
    thomasr1950
    central us
    This is the 1st time the light has ever come on. It's never come on before. I added a 1/2 qt due to it was a little low.
  14. Nov 9, 2013 at 5:48 PM
    jr114
    Jon
    SoCal
    Truck
    Doesn't matter if it hasn't been 6 months. That's for the guys who don't drive 5k miles in 6 months. You've put at least 5k miles since your last oil change (per your previous posts). Your trucks reminding you to change it.
  15. Nov 9, 2013 at 5:54 PM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    09 4X4 V6
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Thats cause your from Canadia (Canada). :canada:
  16. Nov 9, 2013 at 5:55 PM
    OZ-T
    Peter North
    British Columbia
    Yeah , I guess we don't need an idiot light
  17. Nov 9, 2013 at 6:00 PM
    Tiedie
    David
    WFOY
    09 4X4 V6
    Tom, it's time to have the oil changed. No biggy they will reset it. I'm getting ready to go in for 55000 mile service. My light starts flashing at about 500 miles from time to have it serviced , and moves to being on all the time.
  18. Nov 10, 2013 at 10:50 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    The maintenance light comes on at 4500 and just blinks. It will stay on at 5000. If you had service at 28k and now at 32k you have most likely hit your 4500 mark. Go get the oil changed and have them reset it.
  19. Nov 10, 2013 at 10:53 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Also if you're changing your oil your self reset is as follows.
    Turn truck on.
    Change odometer from trip to actual odo. (Not trip a or b)
    Turn truck off.
    Push and hold odometer reset to the right of the speedometer where your fuel gauge is.
    Turn key on while holding reset button in.
    Wait for all the dash marks to dissappear and turn off truck.
    Start truck to ensure completion of reset.
    Enjoy.
  20. Nov 10, 2013 at 10:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Probably because you've always taken it in before 4500 miles.
    At 4500 miles, the light will flash on startup for a few seconds, then at 5000 it comes on solid.
    You had it serviced at 28000 and it's at 32000 now? Seems like it came on 1000 too early... or maybe you had it serviced at 27000 (it should have been serviced at 5/10/15/20/25/30).
