(maintenance question)transmission fluid change 2013 4.0 v6 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomalimited, Jul 24, 2013.
  1. Oct 3, 2018 at 9:08 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Well hopefully it never does.
  2. Oct 3, 2018 at 9:10 AM
    PackCon
    Connor
    It won’t matter as long as the current oils are being changed at appropriate intervals.
  3. Oct 3, 2018 at 9:14 AM
    la0d0g
    running for the hills
    For crawling not hauling
    That was four years ago. You think he figured it out yet?
  4. Oct 3, 2018 at 9:18 AM
    PackCon
    Connor
    Why has it become the new hip thing to thread revive around here?
  5. Oct 3, 2018 at 9:31 AM
    la0d0g
    Better that than starting a new thread for each tire size question me thinks.
    PackCon[QUOTED] likes this.
  6. Oct 3, 2018 at 9:51 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I did a full flush at 125K and will do more frequently now that I know how easy it is. $85 worth of Valvoline MaxLife ATF and a $25 tranny filter is cheap insurance to make your tranny last.
    May as well flush the power steering while you are at it!!
  7. Oct 3, 2018 at 10:14 AM
    glock head
    glock head New Member
    I know that this is an old thread but some information may not have been available 4 yrs ago. Also this information can be helpful to someone buying a used vehicle.
  8. Oct 3, 2018 at 1:09 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    True, it is heat, not miles.
    Not entirely true.
    If you never let the AT fluid overheat the rest of the truck will probably fall apart before the transmission. There are lots, I mean lots of vehicles out there with 200,000-300,000 miles on the factory fluid. And there are lots of other guys out there who spend $300 every 30,000-50,000 miles to replace AT fluid. They will spend 1/2 as much in servicing their transmission as it costs to buy a new one to get and they MIGHT get another 50,000 miles out of it.
    But the hotter you let it get, and the more time you run it hot, the sooner it needs to be replaced. Just ball park numbers, but if you never let the fluid get much over 200*, or if you do for short periods of time the fluid probably is lifetime. If you spend a lot of time in the 210*-220* range changing it every 50K-60K is probably a good idea. If you ever let it get over about 230*-250* it needs to be changed ASAP. Even if that fluid only has a few hundred miles on it.
    If you waited to 120,000 miles and the fluid was that dark the damage was already done. This is a case where I'd have just run what I had until it died. After you've run the fluid hot and done damage replacing the fluid doesn't help. In fact new fluid will accelerate the damage. My 07 has 192,000 miles on the factory fluid and I have it inspected once a year. My fluid is still red and working just fine. I expect at least another 100,000 miles out of the transmission with no service.
    la0d0g and TacomaMike37 like this.
  9. Oct 3, 2018 at 1:26 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    THis post should be stickied. Way too many people have no clue about transmission fluid and how temperature can affect its life. The three go together and will determine when or if it needs to be change.
  10. Oct 3, 2018 at 1:41 PM
    la0d0g
    Well said.
  11. Oct 3, 2018 at 6:03 PM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    But for 240 bucks I'll do itievery 50,000 for the peace of mind. It's not like it's $500 or $1,000.
    TacomaMike37[QUOTED] likes this.
  12. May 9, 2022 at 10:55 AM
    GreggyG
    GreggyG Well-Known Member
    is the spec for the oil temp between 97-115? Or is it supposed to be at 115 degrees? I'm asking in case I just get my OBDII scanner to just tell me the temp.
  13. May 9, 2022 at 5:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Between 46°C / 115°F and 56°C / 130°F
  14. May 9, 2022 at 5:38 PM
    GreggyG
    Thank you!
    TnShooter[QUOTED] likes this.
  15. Mar 5, 2024 at 4:01 AM
    #35
    cadmanpilot
    cadmanpilot Member
    Paul
    Chesapeake, VA
    2013 PreRunner SR5 V6
    My 2013 Tacoma has 80K miles on the odometer. I stopped by a local Toyota dealer and enquired about a transmission service. I was quoted $500 for the recommended transmission flush. I went to a second Toyota dealership yesterday and was quoted about $400 for just a drain and fill (single) which was their recommended service - they don’t recommend the transmission flush - but sure charge for abbreviated service. Not sure exactly what to do now.
  16. Mar 5, 2024 at 4:17 AM
    #36
    Clearwater Bill
    Billy
    Largo Florida
    Go to a trustworthy independent shop.
    Doc Samson likes this.
  17. Mar 5, 2024 at 4:25 AM
    #37
    cadmanpilot
    cadmanpilot Member
    Paul
    Chesapeake, VA
    That’s probably my plan. I have a great local shop that has worked on my Japanese vehicles for years but has switched to all German vehicles. Since I’ve been a historical customer, I may still be able to have service performed there but have not heard back from them yet.
