Maintenance Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by parrishr13, Sep 11, 2011.
  1. Sep 11, 2011 at 8:45 PM
    parrishr13
    parrishr13 [OP] Active Member
    RP
    Keller, TX
    2009 TRD Sport
    OEM
    I just purchased a one-owner, used 2009 Tacoma TRD Sport with 35k miles. I was curious if the previous owner had done the recommended maintenance, so I briefly inspected the truck and have since replaced both air filters (see pics here and here).
    I see what I should do here, but is there anything else I should do or look out for? Thanks for the help!
  2. Sep 11, 2011 at 9:00 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2005 4x4 DC TRD Off Road
    11 Color Matched Grille, Pro comp 7089s, 265/70/17 Wrangler Duratracs, Black Running Boards, Tinted Windows, Bed mat, Weathertech Floorliners
    This is a good guide.
    Edit: You basically posted the same maintenance schedule... LOL.
  3. Sep 11, 2011 at 10:59 PM
    saugus
    saugus Well-Known Member
    Engine oil:
    4.0 L = 4.8 quarts
    2.7 L = 6.1 quarts
    manual trans:
    4.0 L = 1.9 quarts
    2.7 L = 2.7 quarts
    WTF:smash:
  4. Sep 11, 2011 at 11:13 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    4.0 = less motor oil then 2.7?
  5. Sep 11, 2011 at 11:17 PM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
    Go to Toyota Owners and register, add your VIN once registered. If any maintenance was done by Toyota it will show up there.
  6. Sep 11, 2011 at 11:18 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Oil changes every 5,000 miles.
    FYI: Transmission is sealed, no dipstick, no need to check fluid.
    I had a 2005 & had 175,000 miles when I traded it. Only issues were factory battery at 5 years, universal joint replaced at 120,000 miles, wheel bearing replaced @ 165,000 miles.
    I just did normal maint: spark plugs @ 50,000 miles, Oil changes @ 5,000 miles(easy to do yourself, oil filter is on top of engine), Toyota pink engine coolant (only use this, not the cheap store brands) @ 100,000 miles, Brakes when needed, periodically check the air filter ;I have the K&N & wash & re-oil(with the kit) it every 20,000 - 25000 miles. Transmission service around 120,000 miles, Rear differental service around 100,000 miles.
    I ran synthetic oil from 80,000 miles going forward. Mostly because I didn't know much about synthetic till then. You can always find deals at the autoparts store for synthetic oils. Autozone has a $10 off coupon till Sept 24th. Usually autoparts synthetic deals are around $25-$30 with oil filter. The dealer charges from $45-$60 for synthetic.
  7. Sep 12, 2011 at 6:19 AM
    parrishr13
    RP
    Keller, TX
    2009 TRD Sport
    OEM
    I actually found that link in a previous search, and have already registered. Question; is there a point to go in for the accelerator pedal? Or can I just replace mats. I have seen mixed results when I searched.
    Thank you so much. This was the information I was looking for. I do have a question for you. What synthetic oil would most Tacoma owners recommend?
  8. Sep 12, 2011 at 4:30 PM
    genxer36
    Sean
    Bethlehem,GA
    I think most synthetics are the same. I usually get whatever is onsale or has the best deal.
  9. Sep 12, 2011 at 8:15 PM
    parrishr13
    RP
    Keller, TX
    2009 TRD Sport
    OEM
    In my previous vehicle I used Mobile 1 5w-30, and OEM oil filters. Does it make a difference in these Tacoma's what oil filter to use?
  10. Sep 12, 2011 at 8:21 PM
    genxer36
    Sean
    Bethlehem,GA
    I buy my filters from the dealer. The more I buy the more I save. I bought a case last time & it worked out to I think $3.50 a filter. Also get the crush washers (they are inexpensive) for the drain plug.
