maintenance reminder symbol
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nailersniper, Oct 17, 2017.
  1. Oct 17, 2017 at 5:46 AM
    nailersniper
    nailersniper [OP] Well-Known Member
    2017 Limited double cab
    How do I get rid of this?
  2. Oct 17, 2017 at 5:56 AM
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    The manual has that information. I know for the SR it involves holding the trip reset while the key is in the 'on' position, but I also know it's different for you because you have a different cluster. Also, I just googled it and there are some videos as well.
    Garyji likes this.
  3. Oct 17, 2017 at 5:58 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
  4. Oct 17, 2017 at 7:22 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
  5. Oct 17, 2017 at 7:26 AM
    IPNPULZ
    going to be fun!
    ■Resetting the reminder light (vehicles without a multi-information display) or the message (vehicles with a multi-information display) indicating maintenance is required (U.S.A. only) After the required maintenance is performed according to the maintenance schedule, please reset the reminder light or the message. To reset the reminder light or the message, follow the procedure described below: Turn the engine switch off. Vehicles without a smart key system: While pressing the “ODO/TRIP” button (P. 88), turn the engine switch to the “ON” position. (do not start the engine because reset mode will be canceled) Vehicles with a smart key system: While pressing the “ODO/TRIP” button (P. 88), turn the engine switch to the IGNITION ON mode. (do not start the engine because reset mode will be canceled) Continue to press and hold the button until the odometer displays “000000”. ■Allow inspection and repairs to be performed by a Toyota dealer ●Toyota technicians are well-trained specialists and are kept up to date with the latest service information. They are well informed about the operations of all systems on your vehicle. ●Keep a copy of the repair order. It proves that the maintenance that has been performed is under warranty coverage. If any problem should arise while your vehicle is under warranty, your Toyota dealer will promptly take care of it.
