Maintenance Required Light at 19.6k miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomahunt, Apr 20, 2020.
  1. Apr 20, 2020 at 6:34 PM
    tacomahunt
    tacomahunt [OP] Member
    I've hunted through google but can't seem to find out what Maint. could be required at precisely 19.6k mileage...the maint list is quite long and the dealer i'm going through is NOT a toyota dealer so I'm hesitant to request this get checked out...as they are out of state and could easily 'reset' the light and say 'it's fine.'
    Truck is only a year old...should I worry? It's obviously under warranty still so I'm definitely taking it to toyota once it's delivered for an inspection..regardless.
    Thanks in advance
  2. Apr 20, 2020 at 6:38 PM
    Tallgrass05
    Tallgrass05 Well-Known Member
    Did you change your oil at 10k miles? Could be your oil change reminder coming up.
  3. Apr 20, 2020 at 6:39 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    You do know this light comes on 5,000 miles after being reset, right?
    Did your truck not come with a user manual?
    Lt. Dangle, beergeek and AKGSD like this.
  4. Apr 20, 2020 at 6:43 PM
    heybronicetacoma
    heybronicetacoma Meat Popsicle
    Claro
    Seattle
    ‘20 DCSB MT OR SSM
    Mods? Yes.
    IIRC it says maint required "soon" 500 miles before the 5k mark since last reset
    shakerhood and tacomahunt[OP] like this.
  5. Apr 20, 2020 at 6:43 PM
    tacomahunt
    I don't own the truck yet...the deal is pending. I did read that the light comes on every 5k miles and also read through the online pdf manual. Thanks for the quick responses guys.
  6. Apr 20, 2020 at 6:50 PM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    For 20k its just gonna be an oil change and a tire rotate.
    tacomahunt[OP] likes this.
  7. Apr 20, 2020 at 6:51 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Take a deep breath and relax. Nothing wrong with the truck, it just means the truck's last service was done about 400 miles early. Nothing to be concerned with and honestly might be a good thing. Sounds like someone took it in to be serviced as soon and the "maintenance required soon" light came on, which is about 500 miles before the "maintenance required" light comes on
  8. Apr 20, 2020 at 6:51 PM
    tacomahunt
    @AKGSD I certainly hope so. Thanks for the potential stress-relief guys!
  9. Apr 20, 2020 at 6:53 PM
    tacomahunt
    @Amanelot Thank you so much for that, man. My first time buying out of state so I'm being overly cautious and supremely hyper-focused on the details.
    Amanelot likes this.
  10. Apr 20, 2020 at 6:59 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Ah. Worth checking to see how dark the oil is.Might as well change it yourself once you buy though anyway. That way you know what went in it and when.
  11. Apr 20, 2020 at 7:08 PM
    Amanelot
    Amanelot Member
    Texas
    Nothing wrong with that! And it sounds like you're getting an extended test drive which is great! If you like the way it drives, then you should definitely buy one. These are solid, long lasting trucks
  12. Apr 20, 2020 at 7:23 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    The maintenance light turns on for each 5000 mile interval service 500 miles before the 5000 mile mark and has to be reset but does not necessarily turn on every 5, 10, 15, 20k, etc miles. I did my 15k service at 17k miles and just did my 20k service two weeks ago but no maintenance light was on.
