Maintenance required light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eccey, May 25, 2011.
  1. May 25, 2011 at 5:10 AM
    eccey
    eccey [OP] Member
    Christopher
    Long island NY
    How do I reset the maintenance required light that comes on when an oil change is needed???? ( after the oil is changed of course)
  2. May 25, 2011 at 5:15 AM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
  3. May 25, 2011 at 5:15 AM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
  4. May 25, 2011 at 5:31 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Welcome to TW! The fellas above gave you links on here to fix the light, but you should check out that book in your glove box, lots of good stuff in there.
  5. May 25, 2011 at 10:15 AM
    eccey
    eccey [OP] Member
    Christopher
    Long island NY
    Guys ... thanks for the info ..... It worked just as it should .....@ mike ... Unfortunately I purchased this vehicle used and there was no owners manual for me to check
  6. May 25, 2011 at 10:21 AM
    Pugga
    Massachusetts
    F-150 Mod
    Yikes man! There really is a lot of useful stuff in there, I'd try to find a spare either on E-bay or maybe someone on here has an extra (or the stealership but they'll rape you on the cost I'm sure).
