Maintenance Required?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FNH5-7, May 1, 2017.
  1. May 1, 2017 at 3:01 AM
    FNH5-7
    FNH5-7 [OP] Well-Known Member
    Fresno County
    In the past, when I turned on my truck. The maintenance required light would stay lit for 2-3 seconds after the truck was turned on, along with the airbag light then go away. I believe this is normal?
    Recently, the maintenance required light blinks a few times, and longer than it was staying lit before. The blinking maintenance required light goes away, but it blinks several times when I turn on the truck.
    3 weeks ago I had the valve cover gasket replaced by the dealer. A few days afterwards I had an oil change done on the truck. Truck has been run less than 1k miles since the last oil change. I can get exact miles later. Any idea why the maintenance required light is blinking?
    Long ago I've had this maintenance required light turn on and stay on but this is the first time it's blinking right after turning the truck on. Am I over reacting? I guess I'm just curious since I had the truck serviced so recently.
    Anyone experience something similar? If it had been 4-5k miles since the last oil change on the truck this wouldn't worry me and I'd just take it in but like I said, I haven't even reached 1k since the last oil change.
    This is a 2008 Tacoma btw.
    Thanks
  2. May 1, 2017 at 3:16 AM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Normal. Your maint required light was not reset by the person performing your oil x likely because you were before your interval was due. The light blinks upon startup to remind you that the 5k interval is coming up, at which point will stay lit. You can reset the light yourself using the trip meter button , there are instructions elsewhere on TW
    asuchemist and Norton like this.
  3. May 1, 2017 at 3:23 AM
    IronPeak
    AuggieX
    Back to Back
    Justturned off the "Maint Required" light
    * Turn the ignition switch to the “On” position, but do not start the engine
    * Press the odometer button until you see “TRIP A” on the little display
    * Next, turn the ignition “off”
    * Press and hold the Trip Odometer Reset button, and turn the ignition switch to the “On” position
    * Continue to hold down the Trip Odometer Reset button until “000000” MILES appears on the display and the maintenance light turns off.
    Vsolano, 1Shifter and Norton like this.
  4. May 1, 2017 at 3:26 AM
    FNH5-7
    Fresno County
    I've recently done about 1k in services and maintenance so that I can sell my truck and get another Tacoma and small shit like this just makes me go crazy thinking I might have to dump another 2-300 dollars.
    Many Thanks
  5. May 1, 2017 at 3:29 AM
    Clearwater Bill
    Billy
    Largo Florida
    Because it's within 500 miles of it's 5000 mile 'on steady' cycle.
    It's just a mileage 'clock'.
    Whoever changed your oil last didn't reset it. Probably forgot, because it wasn't on yet.
    Basic stuff like this is in the owners manual.
    Lester Lugnut and Norton like this.
  6. May 1, 2017 at 5:28 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Maintinence light is an oil change reminder light. It blinks to let you know the 5,000 is approaching and stay lit after 5,000 miles.
    Your owners manual should tell you this.
  7. May 1, 2017 at 7:44 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1 to all of this. The "Engine Oil Replacement Reminder Light" is covered on pg 159 of your Owner's Manual, available for download from the Toyota Owner's site.
  8. May 1, 2017 at 7:58 AM
    1mike1888
    1mike1888 Well-Known Member
    Gilbert, AZ
    2015 Tacoma TRD Off Road
    An empty wallet
    Thanks for starting this thread this morning. Was literally looking for the same answer as mine started flashing when I left for work.
  9. May 1, 2017 at 8:15 AM
    Norton
    The (renamed) "Maintenance required reminder light" is explained on pg 481 of your Owner's Manual, also available for download from the Toyota Owner's site. Note that the reset procedure is slightly different between early and later 2nd Gen trucks.
    1mike1888[QUOTED] likes this.
  10. May 1, 2017 at 11:42 AM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    There is a smartphone app that works pretty well. It's free, you can create an account, and enter the VIN# and it will pull all the maintenance/service records done at a Toyota dealer. I've started making it a practice to add all the stuff I do too (manually) so that if anyone checks it down the line, it's there. Every time I look at buying a used Toyota, I open the app and add the VIN#, and I can see dealer service records. Pretty handy... plus you get the searchable owners manual on your phone!
    https://play.google.com/store/apps/details?id=com.toyota.towners
    2005 Tacoma reset procedure: (g) Engine Oil Replacement Reminder Light (for vehicles sold in U.S.A.) This light acts as a reminder to replace the engine oil. This light will come on when the ignition key is turned to “ON” and will go off after about a few seconds. When you drive for about 7200 km (4500 miles) after the engine oil replacement, this light illuminates for about 3 seconds and then flashes for about 12 seconds with the ignition key turned to the “ON” position. If you continue driving without replacing the engine oil, and if the distance driven exceeds 8000 km (5000 miles), the light will come on after the ignition key is turned to “ON” position. The light will remain on thereafter. If the light is flashing, we recommend that you replace the engine oil at an early opportunity depending on the driving and road conditions. If the light comes on, replace it as soon as possible. The system must be reset after the engine oil replacement. Reset the system by the following procedure: 1. Turn the ignition key to the “OFF” position with the odometer reading shown. (For details, see “Odometer and two trip meters” on page 145 in this Section.) 2. Turn the ignition key to the “ON” position while holding down the trip meter reset knob. Hold down the knob for at least 5 seconds. The odometer indicates “000000” and the light goes off. If the system fails to reset, the light will continue flashing.
  11. May 1, 2017 at 2:12 PM
    81shark
    81shark Well-Known Member
    it's time for a new frame
  12. May 1, 2017 at 4:51 PM
    FNH5-7
    Fresno County
    That ship has sailed I believe. I was not aware of the recall and the deadline has passed. Luckly my truck is from CA, no snow, no rust.
    Thanks for your input, my 08 Tacoma reset the way you described.
    22repower likes this.
  13. May 3, 2017 at 1:42 PM
    81shark
    you should google the class action lawsuit. it should still be covered under those terms.....
  14. Oct 4, 2020 at 11:14 AM
    Vsolano
    Vsolano New Member
    Victor
    South dakota
    White Tacoma 2017
    Thanks you for this!
