Maintenance Required!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by calaniz0312, May 3, 2010.
  1. May 3, 2010 at 10:37 AM
    calaniz0312
    calaniz0312 [OP] Well-Known Member
    Carlos
    Mission, TX
    05 PreRunner SR5
    Pop a Lock tail gate lock, Dee Zee Heavy Duty bed mat, Viper alarm system, Blacked out headlights, Blacked out tailights.
    My "Maintenance Required" light came on. I took it to the auto parts store thinking he could pull out the code only to find that I confused it with my check engine light so of course no code. Give me a break, it's my first taco. He said it probably needs an oil change. Is he right?
  2. May 3, 2010 at 10:38 AM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Most likely, how many miles has it been since your last oil change?
  3. May 3, 2010 at 10:39 AM
    Flynn Diesel
    Flynn Diesel Well-Known Member
    Phoenix, AZ
    2010 PreRunner SR5 Double Cab
    •BFG AT KO 285/70/17, XD Addict 17x9, Light Racing UCA’s, Billstein 5100’s, OME 885’s, Toytec AAL, Seat Belt warning disable, Grill Craft Black MX Upper & Lower Grill, VisionX 55/65 watt xenon Low/High Beam lights. FOG Light only Mod. Tailgate theft prevention mod. Wet Okole armrest mod. Redline Hood Struts, Weathertech floor liners. AMP Bed Extender. Wet Okole Seat Covers. Pioneer P4200DVD
    Mine just came on when I hit 5000K. Time for an oil change.
  4. May 3, 2010 at 10:41 AM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
  5. May 3, 2010 at 10:42 AM
    calaniz0312
    Carlos
    Mission, TX
    05 PreRunner SR5
    It's been about 4000 miles since the last oil change.
  6. May 3, 2010 at 10:43 AM
    PreRunner
    PreRunner Well-Known Member
    put keys in ignition and turn forward, but do not start. hold down the trip reset button in dash until bars flash across screen. keep holding until they go away in a few seconds. that should do it. if thats not it, hold down button then turn ignition. i forget which it is.
  7. May 3, 2010 at 10:47 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    change your damn oil, man... whats wrong with you? why did you not know this, gosh quit wasting our time with this bs
    j/k:D
  8. May 3, 2010 at 11:01 AM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Yep, change the oil with Mobil 1, and reset the meter.
    A how-to is also in the manual.
  9. May 3, 2010 at 1:16 PM
    calaniz0312
    Carlos
    Mission, TX
    05 PreRunner SR5
    Thanks for the info. Now I know. I'm changing the oil.
  10. May 3, 2010 at 2:28 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    And just in case it isn't obvious, the oil change warning system starts coming on 5000 miles after the last time you reset it, not 5000 miles after the oil change. It doesn't know you changed the oil.
