Maintenance with no history on 250k+
Discussion in '1st Gen. Tacomas (1995-2004)' started by psychic_legume, Nov 29, 2020.
  1. Nov 29, 2020 at 4:24 PM
    psychic_legume
    psychic_legume [OP] Well-Known Member
    2002 White Tacoma TRD
    I recently bought a 2002 3.4L 5-speed that's coming up on 250,000 miles. It didn't come with any maintenance logs or history or anything. Are there any service items I should check or have replaced before I go on any major trips?
    TacomaJunkie8691 likes this.
  2. Nov 29, 2020 at 4:30 PM
    DaBears
    DaBears Well-Known Member
    CONUS
    10 trd sport
    Timing belt, water pump, and new plugs. Check the fluids (diffs, trans, oil, and PS) I think that’s about it. Should be good.
    TacomaJunkie8691 and Hooligans like this.
  3. Nov 29, 2020 at 4:32 PM
    Hooligans
    Hooligans Well-Known Member
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Still thinking about it.
    If you are interested in learning a little about what’s happening in the engine you might send an oil sample to Blackstone.
  4. Nov 29, 2020 at 4:34 PM
    psychic_legume
    What do they do? Just checking gunk and stuff?
  5. Nov 29, 2020 at 4:40 PM
    Hooligans
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    They send back a report that can tell you if you have excess coolant or fuel or metal particles in the oil. With their knowledge of your particular type of engine, they will take a guess at specific causes for their findings. I find it helpful.
    TacomaJunkie8691, Ngneer and GQ7227 like this.
  6. Nov 29, 2020 at 4:45 PM
    psychic_legume
    I'll look into that, thanks!
    Hooligans likes this.
  7. Nov 29, 2020 at 4:46 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Just oil change and spark plugs. That thing will run another half a million miles at least.
  8. Nov 29, 2020 at 4:50 PM
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    This stuff is definitely the first. There should be sticker on the timing belt cover that has the mileage or date when the timing belt was done. Also want to check the air filter.
  9. Nov 29, 2020 at 4:52 PM
    1997tacomav6
    Denver
    Did you do a carfax on the truck,
    Should be some info there
  10. Nov 29, 2020 at 6:04 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Oil change
    Plugs and wires
    Coolant change
    Transmission fluid - Redline MT90
    Transfer Case fluid
    Front diff fluid
    Rear diff fluid
    Upper and lower ball joints
    Steering fluid
    Steering rack bushings
    Itsataco, slander and DashMaple like this.
  11. Nov 29, 2020 at 6:05 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    psychic_legume[OP] and Wulf like this.
  12. Nov 29, 2020 at 6:50 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    You can try checking the Toyota owners website. I found a bit of history on my truck there. You can even download PDFs that show what was done at each service (assuming it was at a Toyota dealer). I can see the work Toyota did for the original owner and myself.
    https://www.toyota.com/owners/my-vehicle/service-history
    dlister70 likes this.
  13. Nov 30, 2020 at 2:28 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Myself I would figure nothing has ever been changed since it left the dealers lot.
    I do this with every vehicle I bought even if the longest trip might be 20 miles.
    Where I live if you run Carfax you get the mileage it was registered and where .
  14. Nov 30, 2020 at 6:43 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Yeah, in most cases the ball joints will fail before the engine does.
  15. Nov 30, 2020 at 6:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    Examine all wear items that could put you in danger or leave you stranded. Replace as needed. (many folks have listed above)
    Examine/test all wear items that would cause you to be uncomfortable
    Change ALL fluids. Just to have a baseline if nothing else.
    I'll guess $1-1.5k in parts if you're lucky. That's with you doing the labor.
    Since you must not have had a pre-purchase inspection from a pro, hopefully you got it for a great price to allow for the updates.
    Personally I drive a vehicle like this a few months around town only, or not out of AAA free tow range, until I'm confident things are as they should be. Because road trips are actually the easiest / least wearing on any vehicle.
    Question. Since you are psychic, why don't you already know all this stuff?
    Wyoming09 and Wulf like this.
  16. Nov 30, 2020 at 8:16 AM
    psychic_legume
    Thanks, this really helps!
    IDK what you expected, a bean is still a bean even if its psychic :notsure:
  17. Nov 30, 2020 at 9:01 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    As others said, basically assume none of it was done since it left the factory.
    Search around here or just on google and you'll find a list of factory recommended service intervals and what needs to be done at each servicing. Every 5k miles do these things, 10k miles do these, etc...
    Timing belt is important, but keep in mind it's a non-interference engine so worst case scenario you come to a gentle stop and get a tow. at 250k, you should be on your 3rd one, but people push the mileage on these all the time.
    However, if your BALLJOINTS fail, that is a catastrophic failure and can be quite dangerous if you're at highway speeds. The spec for when these are "worn out" is very small and requires a special tool to even measure. Most people don't bother even trying, and just replace them anyway. If there's a doubt, replace them.
    First, though, do a close visual inspection. Look at all the rubber bits (suspension/steering bushings, belts, vacuum hoses, etc...). Check all the fluids. Having driven it should give you an idea of some of its deficiencies. Does it wonder down the road, does it seem low on power? Any check engine lights or codes? If everything drives fairly normally, then you probably don't need to worry (at least right away) about things like plugs and wires, and stuff like that.
    So, I'd start with the ball joints. With a pitman arm tool, it's a 1 hour job. When you change all the fluids, a close inspection can help reveal the status of the internal parts. Then do all the rubber bits. The timing belt can seem like a big job, and it is, but if you take your time and do lots of reading beforehand, you can DIY pretty easily. There is a kit a lot of us here have gotten off Ebay from "aircabinman" with all OEM parts for ~$300. Lots of write-ups on it here, too.
    So, just refer back to the factory maintenance schedule, and pic the things that you feel are the worst off, or are the easiest to do and over the next several months knock them out.
    TacomaJunkie8691 and Wyoming09 like this.
  18. Nov 30, 2020 at 9:03 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I guess what he meant was, even if you had a maintenance history, you shouldn't always trust it and just do the maintenance anyway.
    The truck is used, bought from a stranger. Anyone can lie to your face about what's been done so why chance it?
    This is what everyone should assume when buying a used vehicle.
    Wyoming09 likes this.
  19. Nov 30, 2020 at 9:13 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Unless you have seen the vehicle being serviced or have seen it around.
    Like it belonged to your Ex-wifes third cousin.
    Service records are so easy to Make!! Even better have records of work you paid for that was never done.
    People tend to forget to most people a vehicle is something to go from point A to B get serviced at the Quicky Mart Auto Center you don`t tuck it in at night in the heated garage and put the electric blanket on for those nippy nights .
    Then the just plain clueless who really have no clue
    Kwikvette[QUOTED] likes this.
  20. Nov 30, 2020 at 9:14 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just basically doing your due diligence.
    Was just trying to clarify the response given to the OP; sometimes I feel I come off a little condescending as well :rofl:
    But really, just trying to give advice...guess it comes out as 'tough love' idk :burp:
    Wyoming09[QUOTED] likes this.
