Maintenance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ShuggieTaco, Jan 16, 2018.
  1. Jan 16, 2018 at 9:26 AM
    ShuggieTaco
    ShuggieTaco [OP] Well-Known Member
    2011 Tacoma
    1.5" level front
    I have a 2011 prerunner approaching 120k miles. When i purchased the truck had 92k miles. I have no idea what maintenance was done up to that point. Truck drives like a champ. Not worried about that at all. Just curious what recommendations anyone has as to what I might should have checked on the truck for repairs and/or maintenance. I want to be able to comfortably put 200k on this truck without batting an eye. I drive about 400 miles a week for work and just want to make sure I’m in good shape with it. Keep I mind I’m used to driving fords that you can’t keep on the road. This is my first Toyota.
  2. Jan 16, 2018 at 9:41 AM
    Zach O
    Zach O Well-Known Member
    Zach
    Texas
    2015 TRD Off-Road SWFTMFW 6 speed
    I would change all fluids including brake fluid and power steering fluid, spark plugs, grease u-joints, inspect ball joints etc. Have you tried looking up the service history to see if some of this has been done?
    gthupman likes this.
  3. Jan 16, 2018 at 9:46 AM
    gthupman
    gthupman Well-Known Member
    Greg
    Raleigh, North Carolina
    '17 DCSB Super White Offroad
    also coolant change, and definitely trans fluid if you have the automatic.
    Anytime I buy something used I like to run through every maintenance item that can (reasonably) be done to start with a clean slate. You never know (even with records) what exactly was done and how it was done so it is worth doing.
    Bringing all of these maintenance items up to snuff is an investment but well worth the piece of mind to make sure you'll have several hundred thousand more miles ahead of you
    not to mention...most of these things can be done by you to save some coin
    xxTacocaTxx and Zach O[QUOTED] like this.
  4. Jan 16, 2018 at 9:50 AM
    Zach O
    Zach
    Texas
    I would also like to add that if you do any of the maintenance yourself keep records. That will help if you ever decide to sell it.
  5. Jan 16, 2018 at 9:51 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    What I would do:
    Rear Differential oil change (every 30k)
    Transmission flush (every 100k)
    Spark plug change (every 30k with copper plugs or 100k with irridium)
    Coolant flush (every 100k)
    Check brake and powesteering fluid and change/flush if they look bad
    New cabin and engine air filter (every 20-30k)
    New battery if it looks factory
    I would have done these things when I bought it at 90k so keep a closer eye on this stuff. Read the manual so you know when things need to be done. Most of these items had a due interval from 90-100k.
    PS My Tacoma is my first Toyota. I’m used to driving Fords I couldn’t get off the road they treated me so well.
    xxTacocaTxx likes this.
  6. Jan 16, 2018 at 9:54 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    xxTacocaTxx and TacomaMike37 like this.
  7. Jan 16, 2018 at 10:10 AM
    ShuggieTaco
    2011 Tacoma
    1.5" level front
    How do i check service records?
  8. Jan 16, 2018 at 10:10 AM
    ShuggieTaco
    2011 Tacoma
    1.5" level front
    Thanks everyone for the help
  9. Jan 16, 2018 at 10:15 AM
    Zach O
    Zach
    Texas
    https://www.toyota.com/owners/vehicle-specification. I think this is the site. I have never done it myself since I bought my truck new.
    Edit. Nevermind that is to look up specs about your vehicle. I believe that if you make an account on the toyota owners site you can look up service records though
  10. Jan 16, 2018 at 5:21 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Yes! All my records from the Dealer - and even My own services (you can enter yourself) are there ....
  11. Jan 16, 2018 at 6:38 PM
    ShuggieTaco
    2011 Tacoma
    1.5" level front
    Thanks i found this and was able to look up. Didn’t find a whole lot past 70,000 mile mark. Of course i bought it at 90,000. Tune up and plugs were done at 70k along with rear differential fluid change. Guess I’m in store for a full over haul maintenance visit.
  12. Jan 17, 2018 at 7:41 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Yep, do it ALL! Start fresh and document everything!
  13. Jan 17, 2018 at 2:35 PM
    ShuggieTaco
    2011 Tacoma
    1.5" level front
    Just got quotes to do it all. Around $700-$750. Not too bad I guess.
  14. Jan 17, 2018 at 3:36 PM
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
    Your truck is definitely not in dire need of maintenance
    You could easily go another year without doing anything. I am not suggesting that you do that, but don’t be eager to give your hard earned coin to the dealer. I would suggest instead to read up on some of the excellent write ups on here and tackle these things yourself.
    By doing this you will learn a lot about your truck, and it is quite rewarding to be able to accomplish these things.
    You don’t have to do them all at once, pick one, buy the stuff you need, and knock it out.
    Post questions if you have doubts, but all of these things can be done in the driveway.
    Just my 2 cents
    xxTacocaTxx, gthupman and irayfz6 like this.
  15. Jan 17, 2018 at 3:41 PM
    ShuggieTaco
    2011 Tacoma
    1.5" level front
    What’s the easiest 2 I could do?
  16. Jan 17, 2018 at 3:51 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Agreed. This is good advice.
  17. Jan 17, 2018 at 4:33 PM
    mike s
    South Carolina
    2019 TRD OR
    The rear differential is pretty straight forward. You need the right size socket
    The plugs are not too bad, read up on it.
    I wouldn’t do the brake fluid or power steering fluid. Mine are still original at 270000 miles no problems
    Next thing I would check is front brake pads, those are really easy on the Tacoma. Don’t change your rotors unless you’re sure they are warped.
    The radiator coolant is not too bad, there are drain points on the block, and the radiator, takes 2 gallons of coolant, get it from Toyota, don’t flush with water! Just drain and refill. Again, great write ups here describing this in detail.
    Last thing I would tackle is the transmission. Lookup gearcruncher’s wisdom on this topic.
    Take your time, you will not regret doing these.
  18. Jan 17, 2018 at 4:45 PM
    ShuggieTaco
    2011 Tacoma
    1.5" level front
    How does yours drive at 270? Mine drives exact same as it did when i bought it 30k miles ago. Have 120k now. I figured the plugs wouldn’t be too bad. Should i do plug wires too? I’ll probably leave the fluids to the shop. Brake pads I’ve changed on a Honda Accord and a ford ranger before.
  19. Jan 17, 2018 at 4:56 PM
    mike s
    South Carolina
    2019 TRD OR
    Mine drives like new, no problems.
    There are no plug wires, the coils are connected directly to the plugs, pretty easy to remove to get access to the plugs.
    In general, everything on the truck is simple with good robust engineering. That is why they remain so trouble free.
  20. Jan 17, 2018 at 5:03 PM
    Pigpen
    Dan
    Northwest Montana
    I would highly suggest changing both of these. Brake fluid is engineered to absorb water. Water vaporizes under pressure and water vapor is compressible. This causes poor braking performance, as well as corrosion inside the system which leads to failure of parts.
    I know less about the power steering system, but have read that not flushing the fluid can lead to failure in this system too.
    syswalla, Markcal and xxTacocaTxx like this.
