Maintenence questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KRUD, Dec 31, 2021.
  1. Dec 31, 2021 at 4:03 PM
    KRUD
    KRUD [OP] Active Member
    Thanks
  2. Dec 31, 2021 at 4:09 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
  3. Jan 1, 2022 at 4:42 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    It looks to me tighten every bolt you see and a few that are hidden.it is amazing the truck holds together with all these bolts that might need tightening. Happy new year! Thanks you TW for keeping all this info together
    wilcam47 and Chew like this.
  4. Jan 1, 2022 at 7:14 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Without sounding snarky- If you weren't certain your truck was assembly correctly, why buy?
    I'd just maintain per the owner's manual, and if Ricky-Ratchet forgot a bolt, well that's what the factory warranty is for. Life is too short.
    wilcam47 likes this.
  5. Jan 1, 2022 at 7:18 AM
    Bishop84
    Bishop84 Well-Known Member
    The prop shaft tighten suggestions are old suggestions that Toyota carried over from the 80s-90s.
    Honestly don't stress it, they just leave it on for maintenance menus.
    As for accessibility, youre thinking of the prop shaft grease, which your model doesn't use.
    KRUD[OP] and TnShooter like this.
  6. Jan 1, 2022 at 1:20 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Lubricate Propeller Shaft - I have been told there is no way to do this on the 21 Tacoma. Is this true?
    The later models DO NOT have zerk fittings in order to do this.
    TKETACO and KRUD[OP] like this.
  7. Jan 1, 2022 at 2:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If there are no Zerks, the only way to line them is to replace them.
    While I don’t the answer as to why they are no longer greasable.
    I can only assume, which is “A sealed joint is better than serviceable joint that is never serviced”
    KRUD[OP] likes this.
  8. Jan 1, 2022 at 2:43 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    There are a couple words that I highlighted, in your text that have make wondering, are any of the listed components loose, rattling, falling off or missing? If the answer is 'No', then it doesn't sound like this is necessary, as stated in your text.
    KRUD[QUOTED][OP] and Tocamo like this.
