Major Decrease in MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jaybo, Jan 22, 2011.
  1. Jan 22, 2011 at 7:27 AM
    Jaybo
    Jaybo [OP] Well-Known Member
    Jaybo Talbo
    SC
    07 PreRunner
    I have an 07 prerunner with 53000 miles on it, but about 2 months ago the gas mileage went from 16-18 mpg in the city to about 10-12 mpg.. anyone know why this could be or any solutions?
  2. Jan 22, 2011 at 7:42 AM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Wintertime gas blend.
  3. Jan 22, 2011 at 7:54 AM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    Also are you up with maint. and have you checked your tire pressure recenlty?
  4. Jan 22, 2011 at 7:58 AM
    JKD
    JKD Well-Known Member
    Could be a combination of things. Winter gas blend, winter driving, tire pressure.
    You're almost ready for your second spark plug replacement. I suppose they could be worn.
    When was the air filter last checked or changed?
    Have your driving habits changed? Even a 5 mph increase in highway speed can cause a big drop in MPG.
  5. Jan 22, 2011 at 8:24 AM
    Jaybo
    Jaybo Talbo
    SC
    07 PreRunner
    I got my last maintenance at 50k, and tire pressure is good. And yeah I had no idea winter time could affect gas mileage so drastically. I know the big 60k mile maintenance is coming up, maybe some things need to be dealt with earlier than that? Also, I have been driving at 70 mph for a 40 mile commute twice a week... I reckon stuff just adds up, I just didnt know if 10-12 mpg is normal at all. Are there ways to avoid winter blend for next year?
  6. Jan 22, 2011 at 8:25 AM
    Jaybo
    Jaybo Talbo
    SC
    07 PreRunner
    Or what exactly is winter gas blend, haha sorry. i like to learn stuff
  7. Jan 22, 2011 at 8:27 AM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road SR5 Impulse Red
    5100's @ 1.25", Scangaugae II, deck plate mod w/AFE Pro Dry S filter, grey wire mod, alarm mod, defrost w/o compressor mod, de-badged, 17" sport wheels powder coated black, 1" B.O.R.A. wheel spacers, 265/70/17 Cooper Zeon LTZ's, sockmonkey beside decals.
    they put additives to prevent frost and ice build up in fuel systems which kills mpg's.
  8. Jan 22, 2011 at 7:08 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I am down about 2 mpg also.
  9. Jan 23, 2011 at 12:09 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Not a bit of it. You lose more than .3-.7 mpg on "winter gas" you've got a serious engine problem. Or at least engine control problem.
    Hanging brakes, bad wheel bearings, clogged injectors... much more than that and you should be saying "and its running rough or weak".
    Are you in 4x4 the whole time? That'll bring it down some.
    You're right in the bottom end of wheel bearing failure mileage. Ice can hang the parking brake (didn't catch your area, and can't see while typing).
    Get an IR thermometer (little pistol grip thing with a laser pointer) and shoot each wheel/hub. They should all be about the same after driving. If one's 1300 degrees, you've got a problem. If it is a hanging brake, I'd say its a rear, or you'd be complaining about it driving off the road.
  10. Jan 23, 2011 at 12:12 AM
    island808
    Jedediah
    hawaii
    Its a price vs pollution vs regulations thing. Does not reduce energy nearly like a lot of the wikken folk around here believe it does.
    http://www.theoildrum.com/story/2006/9/13/234043/431
    10-12 mpg is hard to get in a 6 speed 4x4 worst I've gotten is 16 while hammering it around during a death metal relapse. Without a mechanical problem, you got to drive like an small dicked teen to get that. Or have massive tires and injectors. Which is like the same thing. To be terribly assy.
  11. Jan 23, 2011 at 1:17 AM
    BartStar
    BartStar Well-Known Member
    pa
    2011 Tacoma 4X4 Double Cab, 6 speed man
    bad O2?
    bad water temp sensor?
    send a signal to the ecu that the engine is always cold and it uses more fuel?
    (you guys do know an O2 Sensor has to breathe (or suck in air) where the wire harness meets the metal of the O2, so a dirty or covered with mud O2 sensor will give a bad reading)
    I am just guessing whats wrong, but its easy to take a quick look at ur O2 sensors and make sure they are clean.
  12. Jan 23, 2011 at 1:29 AM
    soljah111
    soljah111 Well-Known Member
    Jon
    Denver
    11 supah white OR
    None yet
    What about cleaning the Maf sensor? I cleaned the one in my 98 4runner and it helped alot with gas mileage...
  13. Jan 23, 2011 at 5:04 AM
    BartStar
    pa
    I agree! The mass air flow sensor will give bad mpg,, inspecting and cleaning it doesn't hurt.
    (all of these sensors tell the ecu to adjust the fuel (injectors stay open longer)
  14. Jan 23, 2011 at 5:32 AM
    Jaybo
    Jaybo Talbo
    SC
    07 PreRunner
    I'm definitely thinking its something to do with the injectors.. when i was going only 230 miles on a full tank, my friend told me to try to put some "lucas" stuff that goes into the gas tank and is suppose to somewhat clean the fuel injectors. And it helped my mpg to go up to about 13 or 14. I'm due to get that whole fuel system and injectors cleaned at 60k miles i believe. And for running rougher or weaker during this downturn in mpg's.. You could say i could tell a slight difference from before, but not too much of a difference. Just enough to where it was slightly noticeable. I'm just debating on skipping my 55k mile maintenance and just getting the big 60k mile one done early and hopefully that'll help? or maybe at least to give the dealership a chance to assess to the problem.
  15. Jan 23, 2011 at 5:36 AM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    Ethanol???
  16. Jan 23, 2011 at 11:44 AM
    Jaybo
    Jaybo Talbo
    SC
    07 PreRunner
    And this may be important to fit into the equation that i forgot about.. I read about another guy getting about the same amount of mpg as me on here, and him and i are running 265/75/16 tires and doing in city driving.
  17. Jan 23, 2011 at 11:55 AM
    island808
    Jedediah
    hawaii
    ya don't lose 4-10 mpg on 10% ethanol.
    Other than the maf sensor being damaged slightly.. I would think any of those other things would throw codes. Maybe they wouldn't turn on the CEL if they didn't cause too much pollution and wouldn't blink it unless they were going to blow up the engine.
    Pull your codes and see... You shouldn't have any..
  18. Jan 23, 2011 at 7:58 PM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '10 Access SR5 4x4 4cyl
    On top of the Winter blend that I've found does cut mpg, there is of course longer warm up times for engine, oil, and tires. But in many places, including counties around the major urban areas of PA (Phl, Pitt, Scranton W-B) there is a mandated change to an oxygenated fuel (October to May) that is even less efficient. Couple that with it being yet another excuse for fuel distributors to tack a couple cents/gallon onto their pump prices and it makes a serious dent in your mp$. The combination generally results in about 10% worse fuel mpg and a couple percent more expensive. My fuel cost per mile is about 13% worse in winter. It is a little hard to make this comparison since the price of gas is pretty fluid for more reasons than I can keep track of.
  19. Jan 23, 2011 at 8:31 PM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    I'm down about 1-2 mpg right now...
