Major leaf pack install... FAIL!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by meatman, Jul 13, 2011.
  1. Jul 13, 2011 at 1:51 PM
    meatman
    meatman [OP] I deal with dead animals
    Greg
    Murphy N.C.
    (built) 04 Tacoma SR5 4x4 and 01 TRD 4x4 DD
    So after having my new set of Wheelers 5 leaf pack for a week I decided today was the day to install. went over to a friends house to put these and the 5100's on (he has air tools) it took around 2 hrs. to remove one U bolt there was no rust showing at all. I also sprayed pb blaster on them for the last 7 days each day. We got one off and relized that it most likley has had som locktight or something on the threads. So it sits in his driveway me driving his car and really PISSED OFF! I thought i took in account every bad scenero. long story short had NAPA order me new u bolts and the will be in fri. CRAP Crap Crap (hell with installing the front 5100's im taking it to a shop instead)
  2. Jul 13, 2011 at 1:58 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    If there's locktight on them just get a propane torch and heat the nuts up a bit. Also, you need to install new u-bolts any time you replace the springs anyway.
  3. Jul 13, 2011 at 2:00 PM
    motorsport36
    motorsport36 Morto un papa, se ne fa un'altro
    Furnace, AZ
    2016 Tacoma TRD Off road 4x4 DCLB
    ^heat up the nuts :rofl:
  4. Jul 13, 2011 at 2:02 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    ^this. I think even vAuto zone will have u bolts. cutt the old ones off with an angle grinder or torch and get to work!
  5. Jul 13, 2011 at 2:04 PM
    meatman
    Greg
    Murphy N.C.
    I didnt think I had to because they were not all that rusty. I got some ordered from NAPA for 68.00 bucks will be here on fri. I am guessing it is locktight but dont know for sure there is a whitesh substance on the top part of threads.
  6. Jul 13, 2011 at 2:07 PM
    meatman
    Greg
    Murphy N.C.
    Went there and they nor Oreileys had any that matched up not even in a longer lenghth, Napa was the only one that told me they could order them
  7. Jul 13, 2011 at 2:07 PM
    FFRNDAN
    FFRNDAN Well-Known Member
    Dan
    Edinburg, Oh
    09 Acess Cab 4x4 MGM
    In most cases, the old U-bolts are just cut off, quick work with an angle grinder. Same goes with old shock bolts. New bolts are cheap insurance anyway.
  8. Jul 13, 2011 at 2:16 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    33's,armor,crawler,dents, ect
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Truth^ Just like grade 8 bolts "supposedly" when you tighten them once it tweaks it. Thus will never be able to be torqed down properly again. That being said there is probably noone who actually follows those guidlines:D OP Sounds like you need breaker bar+5 foot long pipe over breaker bar promise you it will come off (in one peice or 2). Unless the socket breaks but you should be fine with an impact socket.
  9. Jul 13, 2011 at 2:24 PM
    meatman
    Greg
    Murphy N.C.
    Did the breaker bar and pipe thing to get the one ubolt off and since i got them ordered from napa i am gonna cut the rest of the suckers off and throw them in the bottom of lake BLUE RIDGE!
  10. Jul 13, 2011 at 2:30 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Yup, just get new ones. U-Bolts tend to stretch when mated with the HI-Nuts..
  11. Jul 13, 2011 at 2:35 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Your problem is most likely thread stretch which happens to about 95% of U bolts, they can appear rust/dirt/mud free but the test for them is how hard it is to loposen them, example: You break one of the nuts loose & it backs off of the U bolt to where you can see daylight between the nut & anything it made contact with, you think "Hmmm WTF is going on ? this nut ia hard as hell to turn & its not touching ANYTHING !" This.... is thread stretch, the threads on the U bolt have acually "stretched" making it (the nut) actually get harder to turn instead of getting looser, this U bolt will have to be cut off. As for reuse, I've had mine on & off 4 times & still using originals, my thread stretch was minimal, but if $$$ isn't an issue get new ones, if you're dirt ass poor like me, then you re use where possible.....;)
  12. Jul 13, 2011 at 2:40 PM
    krimson
    krimson Nothin
    TRD Off Road
    You could use a cheater bar to break free the bolts. If me and my friend can get U-Bolts off A 92 Chevy 2500 to get a 14-Bolt using an improvised cheater bar using an exhaust pipe off of a 99 Camaro in a junk yard. Then you can def do it with an 01.
  13. Jul 13, 2011 at 2:47 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    The white stuff isn't locktite..it's corrosion..
    I know because my grade 8 hardware on my lower BJs has the same stuff..and it's def not locktite because I PUT THEM IN MYSELF..and they haven't broke..over the past 1.5 years. Grade 8 ftw.
    I'd rather stick with worn u-bolts then using Vatozone u-bolts:eek:
    Just like the idiots who install aluminum blocks in their trucks...I broke 2 sets of aluminum blocks, and I personally have seen damage from when aluminum blocks break.. bye bye rear end.
    Protip: Put a jack and wood under your overload when un-torquing u-bolts. It will save you from a mini heart attack, and possibly a smashed finger between your wrench and leaf pack
  14. Jul 13, 2011 at 2:49 PM
    meatman
    Greg
    Murphy N.C.
    This make the most sense to me i had to use a breaker bar and a 4 ft. pipe all the way to get the nut off. I must have had the worst case of thread stretch then. Gonna cut them off and STILL throw them in the bottom of Blue Ridge lake.. And drink several malted beverages as i flip them the middle finger!
  15. Jul 13, 2011 at 2:54 PM
    creeper
    creeper Well-Known Member
    Huh? Which language was this grammar derived from?
  16. Jul 13, 2011 at 3:10 PM
    TacoSID138
    TacoSID138 Well-Known Member
    SoCal
    04 PreRunner TRD
    Faded out tinted tails and 3rd brake light,deck-plate mod, dumped Flow Master 40, King EXTD coil overs, 1.5 AP shackles, AP EXPD leafs. 285 Hankook DynaPro ATM tires
    He's replacing the whole pack, not adding a add a leaf. So I'm sure there's no need for that in his case.
  17. Jul 13, 2011 at 3:14 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    :laugh::laugh: Lol, I feel your pain man, been dere , done dat !!
    I feel for anybody that lives in a cooler ,wetter climate & having to deal with removing ANYTHING from undercarriage, absolute hell....:eek:
    OFF TOPIC:
    Doesn't anyone use that old spray undercoating that used to smell like you just paved a highway when you were done ?? ( I think it was creosote based) Anyway that shit was a 4 can, once a year application from bumper to bumper underneath, nothing got thru that stuff, but they probably had to stop using it due to EPA reg. (this stuff actually worked!);)
  18. Jul 13, 2011 at 3:56 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Unless you have a impact wrench and compressor with some balls the next move is the acetylene torch!
  19. Jul 13, 2011 at 5:57 PM
    Creep3r
    Creep3r New Member
  20. Jul 14, 2011 at 10:44 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Naww man not paranoid just careful nothing wrong with that, ;)
    For the record though the axle alignment pin is what holds the pack together for the most part, as long as its not sheared or loose, you're good to go
