Major mods this summer; advice?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RedandBlack, Jun 21, 2013.
  1. Jun 21, 2013 at 1:58 PM
    RedandBlack
    RedandBlack [OP] Active Member
    Justin
    TX
    06 Murdered
    20" tires, moto metal rims w/ red inserts, 2 10" kickers, 2 6x5 type R speakers front, 2 6x1 infinitys back, 300 watt apline 4 channel amp, 1000 watt kenwood amp, pioneer AVH-p2300 Deck, Halo CCFL Black healights, Chrome billet grill, Blacked out badges, Blacked out tail lights, Pioneer DVD player,
    Some I'm looking to do some big additions to my taco this summer. All I have planned is I want to add a Procomp or Fabtech 3" body lift, put on some mud tires ( preferably nitto trail grapplers), a badass satoshi from Homertaco, a K&N cold air intake, and finally a american thunder duel exhaust. And I'm just curious how to best approach those things. For example what all should i get to do the lift? I just feel like I'm missing a importantpart to the lift.
    so any advie would be greatly appreciated
    Thanks
  2. Jun 21, 2013 at 2:01 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I wouldn't get a body lift... I'd do it right and get a proper suspension lift.
  3. Jun 21, 2013 at 2:02 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    :duel:
    Are you dead set on a body lift? Just curious as to why if you are.
  4. Jun 21, 2013 at 2:10 PM
    RedandBlack
    Justin
    TX
    06 Murdered
    Whats the difference between the two? I'm just looking for a 3" lift to fit some offroad tires lol.
  5. Jun 21, 2013 at 2:19 PM
    Pugga
    Massachusetts
    F-150 Mod
    The difference is form over function and form. The body lift strictly lifts the body higher, everything else stays at the same height. A suspension lift will often improve performance, the suspension will take bigger hits and ride better in many cases. Plus, I do not think body lifts are overly safe.
  6. Jun 21, 2013 at 2:22 PM
    RedandBlack
    Justin
    TX
    06 Murdered
    Oh okay, for a suspension lift do I need to replace all the suspension?
  7. Jun 21, 2013 at 2:25 PM
    Pugga
    Massachusetts
    F-150 Mod
    Do you off road, or tow/haul?
    Cheapest option is blocks and top plate spacers but not much better than a body lift. Next cheapest and actually a good lift would be Bilstein 5100's for the front and an AAL for the rear. Bilstein 5100's use the stock coils but preload them to gain lift. You can gain up to 2.5" of lift from the Bilstein shocks alone. You could re-use the stock shocks for the rear although aftermarket might ride a bit better but the AAL would give you the lift for the rear.
  8. Jun 21, 2013 at 2:30 PM
    RedandBlack
    Justin
    TX
    06 Murdered
  9. Jun 21, 2013 at 3:40 PM
    Grieby54
    Grieby54 Horsebit
    Sam
    Castle Rock, CO
    '13 TRD Off Road 4x4 DCSB MGM JBL/Entune/Nav
    WeatherTech Digital Liners, ImMrYo rear view mirror bracket, color matched grille, Tacoma door sill protectors, OEM hood protector, clear bra, tint, OEM roof rack, trimmed front mud flaps to match rear clearance, debadged, color matched grille, Plasti Dipped front Toyota emblem, OME 884X coils with trim packer on driver's side, OME Nitro Sport 9000 shocks, Deaver/ToyTec AAL with OME N182 shocks, 265/75/16 Duratracs, ProComp 7032 16" wheels
    Skip the CAI, too. It's worthless.
  10. Jun 21, 2013 at 4:09 PM
    anotherreject
    anotherreject Well-Known Member
    Just look at one of the site sponsors they can get you on a nice lift kit that will come with all the extra bells bolts and whistle to get you rolling, for what you want it should just be a few hundred dollars. But for what its worth if all you want is bigger mud tires you can just upgrade to 265/70/17 or 265/75/16, based on your wheel size, without spending money on a lift. And its already been said a k and n cold air intake is not worth the money.
  11. Jun 21, 2013 at 4:34 PM
    RedandBlack
    Justin
    TX
    06 Murdered
    Should I just look on the site vendors?
  12. Jun 21, 2013 at 5:02 PM
    Pugga
    Massachusetts
    F-150 Mod
    Yes, the 5100 series shock absorbers.
    Here's some other options for you and some good reading material. I would research a lot more before pulling the trigger on anything.
    http://www.tacomaworld.com/forum/suspension/11282-tacoma-lift-faq-guide-read.html
    First, decide how much lift you want and that will narrow down your options. Because you have a Prerunner, you can use spindles to get your lift and retain your factory ride up front, not have to mess with upper control arms and gain 4" of lift up front. For the rear, you can use a simple AAL.
    Another option would be the 5100's up front. They work by preloading your OEM coils and give you up to 2.5" of lift (maybe a touch more because Prerunners seem to gain a little more lift than the 4x4s). Because they work by preloading the coils, the ride will be stiffer. Same AAL for the rear.
  13. Jun 21, 2013 at 5:34 PM
    RedandBlack
    Justin
    TX
    06 Murdered
  14. Jun 21, 2013 at 6:15 PM
    pivey14
    pivey14 I'm A Grinder
    Patrick
    Baton Rouge, LA
    '11 DC Base PreRunner
    See Build Thread
    I'm a PreRunner as well and I just ordered 5100's for the front along with Eibach coils. You can set the 5100's at .85 and the coils lift the truck 1.6" for a total of 2.5". I bought a 1.5" AAL for the rear. It will be level. All for under $500. Find someone to install it for you or do it yourself and you'll be good to go.
  15. Jun 21, 2013 at 7:09 PM
    RedandBlack
    Justin
    TX
    06 Murdered
    So you're going to be running the 5100's with the eibach coils instead of the stock coils?
  16. Jun 21, 2013 at 7:16 PM
    RedandBlack
    Justin
    TX
    06 Murdered
  17. Jun 21, 2013 at 7:26 PM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
  18. Jun 21, 2013 at 7:35 PM
    Pugga
    Massachusetts
    F-150 Mod
    Careful with Procomp lift kits, they use a very stiff coil! The difference between 5100's and stock coils and an aftermarket coil is the preload. 5100's give you lift by preloading the stock coil, lift coils are longer to begin with so they don't require the preload to give you lift.
    With suspension lifts on a 2nd Gen that near 3", you might find that you'll end up needing new upper control arms to get a decent alignment. 5100's at 2.5 give you about 2.5" of lift and there are many members with that amount of lift that are still using stock control arms. At 3", you will be hard pressed to get a decent alignment. Aftermarket UCA's are in the upper $300's. That was one of the reasons I mentioned spindle lifts. They retain the stock suspension geometry so new control arms are not needed, stock ride is maintained and lift is achieved.
    If you do go with a full coilover kit, check out the Old Man Emu kit from either Toytec or Downsouth Motorsports (make sure you mention you found them through TW if you order through them). OME has a lower spring rate so it'll be closer to a stock ride. OME coils can be mounted on Bilstein 5100's or OME Nitrocharger shocks.
    If you're trying to get to 3" of lift, I'd go OME over the Eibach kit. OME 885 coils with the short top plates get you to 3" without preloading the coils. Eibachs are a stiffer coil to begin with and require you to preload them to get the same lift.
  19. Jun 21, 2013 at 9:55 PM
    RedandBlack
    Justin
    TX
    06 Murdered
  20. Jun 21, 2013 at 10:15 PM
    RedandBlack
    Justin
    TX
    06 Murdered
    I actually think I'm going to go with the full coilover kit, If i get the full three inch lift will I have to get new upper control arms?
