major MPG drop all of a sudden
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tammikm, Jan 3, 2011.
  1. Jan 3, 2011 at 6:47 PM
    tammikm
    tammikm [OP] Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    what would cause my MPG's to drop off all of a sudden? 2006 DC 4x4 SR5, was getting approx 22-24 mpg, now am getting 15 - 16 mpg... seems to run the same but is using way more gas....anyone else have this problem?
    thanks
  2. Jan 3, 2011 at 6:49 PM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    2002 TRD prerunner,SR5, doublecab
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    No warning lites on the dash?
    I would look at 02 sensors first. Could be going bad and dumping more fuel into the system.
  3. Jan 3, 2011 at 7:05 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Your fuelly sig says 19 mpg, so at 16 you are not as far off as you think. Either way you are not giving us enough info to give ideas. At 3 mpg off normal, could be a batch of bad gas, have you been in 4wd a lot lately, towing anything, fuel filter, could be a whole host of things....
  4. Jan 3, 2011 at 7:09 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2005 4x4 DC TRD Off Road
    11 Color Matched Grille, Pro comp 7089s, 265/70/17 Wrangler Duratracs, Black Running Boards, Tinted Windows, Bed mat, Weathertech Floorliners
    Are you using 4wd alot? It kills my mileage...
  5. Jan 3, 2011 at 7:09 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    x2
  6. Jan 3, 2011 at 7:13 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    x2 i went from 22 to 15 mpg after a few times using 4wd. I would imagine cold start up temps, low tire pressure due to cold, and winter gas but were you getting good mileage before winter hit?
  7. Jan 3, 2011 at 7:13 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Winter gas blend .... in Canada ...... in the winter
    4x4 all the time doesn't help either
  8. Jan 3, 2011 at 7:16 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    Eat to much over the holidays? =P
    Probably some bad gas unless its consistent, then I would guess o2 sensors are screwing with your mix.
  9. Jan 3, 2011 at 8:59 PM
    2_wheels
    2_wheels Well-Known Member
    Coeur d'Alene, ID
    06 Tacoma TRD Sport 4x4 dbl cab
    Could it possibly be that you converted KM vs. MILES? I noticed that you're from Canada and just a thought.
    Think about it, 15 Miles = 24.14 Kilometers. Possibility? No disrespect here, I'm merely throwing something out for you. If you really get 24 mpg I want to swap out my US ECU for a CAN ECU!
    I've got the same truck, live in Nevada and the absolute best tank of gas was purchased in Salem Oregon and I got 17.5 MPG on the highway with 2 motorcycles in the back. Turns out it was summer and the refinery was at the same station I bought the gas so I'm thinking it was the "fresh" batch. Typically in the winter I get 15.5 to 16 mpg.
    Happy New Year all!
  10. Jan 3, 2011 at 10:48 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    i'm getting 14-15 on a fresh tune up, tons of air in my tires, and driving like a 89yr old grandma, winter gas sucks and my aerodynamics suck
  11. Jan 3, 2011 at 11:30 PM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    Started using defrost all the time? Winter gas? 4x4? All could contribute.
  12. Jan 4, 2011 at 7:16 AM
    tammikm
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    ya, thanks guys, I'm chalking it up to winter, winter gas, defrost, etc, not in 4x4 much as the roads have been clear... but i suspect its just due to winter...
  13. Jan 4, 2011 at 7:37 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    yea the defroster wont help either since it uses the compressor
  14. Jan 4, 2011 at 7:55 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    U know what i have been getting shitty milage too, I actually went through my truck yest and chrcked diff oiks, spark plug gaps, clean maf sensor, grease u joints ckean filter, I was scully thinking of changing o2 sen and getting a maf sensor. Hmmm maybe its time to invest in a maf, so ut can help my milage, just don't tell the wifey!! :laugh:
  15. Jan 4, 2011 at 8:04 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Sounds like you've been letting the truck warm up before you get in and take off. My money is on the gas burnt up idling.
  16. Jan 4, 2011 at 8:07 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Defrost?
  17. Jan 4, 2011 at 8:53 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    That's why you should do the diy mod to eliminate this, one of the best things I've done to my truck
  18. Jan 4, 2011 at 9:06 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I thought the compressor was only running if you're on defrost and you have the A/C switch lit up? :confused:
  19. Jan 4, 2011 at 11:29 AM
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    Nope, if u use defrost, u use ac, but the ac light won't be on
  20. Jan 4, 2011 at 11:42 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    your right in the ballpark for mpg in the winter...these truck run rich as PIGS
