major mpg loss help!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by waltonhockey17, Nov 18, 2010.
  1. Nov 18, 2010 at 5:04 PM
    waltonhockey17
    waltonhockey17 [OP] Well-Known Member
    Alex
    georgia
    08 DC Red Taco
    4" camburg spindles, billys at 0", 16" xd hoss rims, 285/75/16 xtreme mud terrains
    the past month i have been losing around 60-70 miles of gas. i have no idea what the problem could be. I havent added anything to the truck but my spindles but that was over 3 months ago. i usually get around 300-320 per tank but now im only getting around 250. any ideas?
  2. Nov 18, 2010 at 5:06 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    tune up time? miles??????
  3. Nov 18, 2010 at 5:07 PM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    How many miles on your rig?
    Air filter clean? Injector cleaning? Winter gas additives causes my mpg to go done some. Differential and motor oil fresh?
  4. Nov 18, 2010 at 5:09 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    tire pressure, time to change air filter?
    :notsure:
  5. Nov 18, 2010 at 5:11 PM
    cactuscorn
    cactuscorn Another FNG
    El Paso, TX
    2016 BBR TRD OR AT DCLB w/JBL
    OEM bedmat, Weather Tech mats, JDM ASTAR 800 lumen LED reverse bulbs, blue LED dome light and every cubbyhole filled with crap.
    better keep a eye on the poor kid down the block. how do ya think he gets to the liquer store if hes not tappin yer tank once a week?
  6. Nov 18, 2010 at 5:12 PM
    waltonhockey17
    Alex
    georgia
    08 DC Red Taco
    has 25000 on it. tire pressure is fine. says i dont need to take it in for another 2000 miles
  7. Nov 18, 2010 at 5:15 PM
    sirwamz
    sirwamz Well-Known Member
    Manassas, VA
    05 Tacoma SR5 4X4 Manual
    Not much......college student using the GI Bill to survive.
    Maybe your gas station is switching to the winter fuel mix.
  8. Nov 18, 2010 at 5:15 PM
    waltonhockey17
    Alex
    georgia
    08 DC Red Taco
    dry county:(
  9. Nov 18, 2010 at 5:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    What kinda MPG are you getting?
  10. Nov 18, 2010 at 5:20 PM
    waltonhockey17
    Alex
    georgia
    08 DC Red Taco
    i filled up few days ago, ive used 1/4 of a tank and only gotten 60 miles out of it
  11. Nov 18, 2010 at 5:23 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    It has a screen to prevent that, well the gas part not the 'poor kid'.
    OP, It is winter, and winter gas will cut down on MPG's.
    I would highly suggest new spark plugs, fuel injector cleaner, new diff oil, clean MAF/throttle body, tire balance/rotation, and be very light on the foot pedal.
    And see what happens after all of this........
  12. Nov 18, 2010 at 5:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That doesnt sound too bad. Without knowing the actual "MPG" you cant make an accurate decision as to weather or not there may be an issue.
  13. Nov 18, 2010 at 5:26 PM
    waltonhockey17
    Alex
    georgia
    08 DC Red Taco
    thanks ill look into that. it just freaked me out cause ive had my truck lifted for 2 years and have never had my tank go lower then 280
  14. Nov 18, 2010 at 5:27 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Colder temperatures and winter gas is your explanation.
  15. Nov 18, 2010 at 5:30 PM
    waltonhockey17
    Alex
    georgia
    08 DC Red Taco
    i average about 16.5mpg and now im getting 13 mpg
  16. Nov 18, 2010 at 5:31 PM
    waltonhockey17
    Alex
    georgia
    08 DC Red Taco
    i live in statesboro, GA most days its still hot enough to go swimming outside
  17. Nov 18, 2010 at 5:32 PM
    2011TacoSport4x4
    2011TacoSport4x4 Well-Known Member
    Clyde
    Offutt AFB, Nebraska
    2011 TRD Sport DC 4x4 OME 3" lift
    OME 3" lift, Flowmaster exhaust, K&N Intake, bestop, ARB Locker, 4:56 gears, ARB Deluxe bumper, Warn 8000lb winch, Synthetic line, Rock sliders, exhaust relocation done, All Pro standard 3" leaf packs, Timbren Bump stops, Extended brake lines, Pioneer dual din DVD, Pioneer door speakers, Ultra Gauge, BAMF Lower LCA Skids.
    With my lift and 33's I'm lucky to get 15mpg. I don't know what size your tires are but my gas mileage is pretty bad with 33's. the winter mix doesn't help either
  18. Nov 18, 2010 at 5:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Like mentioned, Colder temps, winter gas = bad mpg. May want to consider changing your plugs to help.
  19. Nov 18, 2010 at 5:33 PM
    waltonhockey17
    Alex
    georgia
    08 DC Red Taco
    i have 285/16 which are 33's, had them for about 2 years this didnt happen last winter
  20. Nov 18, 2010 at 5:41 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    ok.. last guy that was all crazy about how he was losing mileage did not know how to calculate mileage and had a bad fuel gauge.
    If your fuel gauge is at all involved with calculation of mileage, you are doing it wrong.
    You do not ever look at a fuel gauge for anything other than fun. It does not tell you any reliable information and is very prone to failure and bad readings based on many conditions. Not to mention they aren't calibrated to anything at all.
    If you are indeed able to calculate your fuel mileage and are losing that much. You should have one or more of the following: a CE light, heavy soot on the exhaust, overheating (or an overheating brake, catalytic converter or something), performance problems.
    Its not a huge drop but you're not claiming great mileage as your baseline.
