Major Rubbing
Discussion in 'Wheels & Tires' started by JDTRD88, Oct 29, 2010.
  1. Oct 29, 2010 at 7:33 PM
    JDTRD88
    JDTRD88 [OP] Active Member
    Jordan
    Nova Scotia, Canada
    07 Tacoma TRD
    Stock for now
    hi, i just got a set of mickey thompson classic locks and mickey thompson baja ATZ ( 265/75r16 ) first the guy sent me wheels for a chev so i had too get wheel spacers because they rubbed against my caliper, he told me thay should clear even with the wheel spacers, well he was wrong, the rub real bad!!! i dont know what to do? Can anybody help me with this? i dont really want too lift it, and when i did lift it on the jack 3 inch they were still rubbing!!!! can anyone help me?
  2. Oct 29, 2010 at 7:35 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    A lift has noting to do with rubbing your calipers...
  3. Oct 29, 2010 at 7:36 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    neither does wheel spacers
  4. Oct 29, 2010 at 7:38 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    easy fix... take them back and tell "the guy" to send you toyota rims :p
  5. Oct 29, 2010 at 7:59 PM
    JDTRD88
    Jordan
    Nova Scotia, Canada
    07 Tacoma TRD
    Stock for now
    the wheels were rubbing aagainst the calipers, but i was just wondering if its because of the wheel spacers that there rubbing?
  6. Oct 29, 2010 at 8:04 PM
    Yoytoda
    Roland
    completely stock
    bottom line they rub because they arent the right wheels for your truck...
  7. Oct 29, 2010 at 8:05 PM
    ktmrider
    Junk
    ehh some 16 inch rims do rub on the calipers, and the solution is grinding down the caliper
  8. Oct 29, 2010 at 8:10 PM
    JDTRD88
    Jordan
    Nova Scotia, Canada
    07 Tacoma TRD
    Stock for now
    ya, dont really mess around wih grinding the calipers, if i had the right wheels, with the same tire will they fit ?
  9. Oct 29, 2010 at 8:14 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Spacers will increase the clearance between the wheel and the caliper, but will DECREASE the clearance between the tire and the fender well.
    Bottom line, those are the wrong rims.
  10. Oct 29, 2010 at 8:23 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    What you want, roughly, is a 16x8 rim, 4.5 backspacing, 0 to -6mm offset (note the minus sign; that's negative 6!) 6 on 5.5 bolt pattern, and (I THINK 4.25" hub bore)
    Even at those specs, different wheels are cast with different designs and on some of them the spokes just hit the caliper. Nothing to do in that case but pick a different wheel. Some folks will grind down the caliper in this case. I personally wouldn't do that, given how many wheels there are out there that will fit without having to grind them.
  11. Oct 30, 2010 at 2:49 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Not quite. What he wants is a 16" rim with 4.5" backspacing. The offset will depend on the rim width. For an 8 inch wide rim, 4.5" backspacing is 0 offset.
  12. Oct 30, 2010 at 5:09 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Are the wheels rubbing on the outside face of the calipers or on the top edges where it's of the calipers. If it's on the outside face of the calipers you should be able to clear it up with spacers.
    Or you could just to get you $ back and get the correct OS/BS.
  13. Oct 30, 2010 at 7:28 PM
    JDTRD88
    Jordan
    Nova Scotia, Canada
    07 Tacoma TRD
    Stock for now
    thanks for commenting, i just took the wheel spacers off, grinded the calipers and they are fine now, thanks for all the usefull info :D
  14. Oct 30, 2010 at 10:14 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    DOH! :facepalm:
    Corrected in place. I'm not sure how that reversal of terms slipped by me.
