Major Tune-Up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MannyECG, May 31, 2009.
  1. May 31, 2009 at 10:41 PM
    MannyECG
    MannyECG [OP] MasterChief
    Tempe, AZ
    06 TRD Sport, 4x4, D-Cab, Long Bed
    K&N Air Intake, BFG A/Ts, N-Fab Nerf Steps, Tailgate Pop N Lock
    Hi everyone,
    So I'm hitting 50k miles on my truck and finally doing a major and long-overdue tune-up on my truck including changing the spark pugs and changing all the fluids.
    I have a 2006, 4x4, automatic, V6. I do my own oil changes and have read the threads about other DIYs.
    I know I need 3 quarts of 75-90 for the rear diff along w/ LSD additive.
    How many quarts for the front diff? Also 75-90?
    I've also read that the transmission doesn't need a fluid change until 100k miles. True? Or should I also change it? If so, how many quarts and what type of oil?
    My last question is about synthetics. I already run Mobil 1 for the engine, but I've read that there is no good synthetic out there for LSD.
    What is your opinion on switching to full synthetics?
    Thanks in advance!
  2. May 31, 2009 at 11:15 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    as far as i know, DO NOT attempt your own transmission fluid, its not cheap and not easy, unless you have a machine that is made to do it, our tacomas have a SEALED transmission... take it to toyota and have them do it...
    i have the same year, same tranny, same engine, short bed, double cab
  3. May 31, 2009 at 11:30 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
  4. Jun 1, 2009 at 7:15 PM
    MannyECG
    Tempe, AZ
    Wow, I'm glad you confirmed my guess not to do the transmission! It seems so simple to just drain and refill.
    I'm going with 75-90 synthetic for the diffs and t-case.
  5. Jun 1, 2009 at 7:25 PM
    jeff6001
    jeff6001 Well-Known Member
    San Antonio, TX
    99 trd prerunner
    I've done my transmission once and my dad's twice. Maybe cause i've got a 99 and my dad has a 97 but it's not sealed, just a lot of bolts plus you need a new filter and gasket. That's pretty much it. And oil!
  6. Jun 1, 2009 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its much different on the second gens...
  7. Jun 1, 2009 at 7:34 PM
    MannyECG
    Tempe, AZ
    What exactly does it mean when the transmission is sealed? And why would Toyota do it like that?
  8. Jun 1, 2009 at 7:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It means that it is a sealed unit, with no dipstick and is not user servicable.
  9. Jun 1, 2009 at 7:40 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I found this very useful in my 30K maintenance
  10. Jun 1, 2009 at 9:17 PM
    MannyECG
    Tempe, AZ
    Thanks Chris and everyone else!
  11. Jun 2, 2009 at 12:00 AM
    jeff6001
    San Antonio, TX
    99 trd prerunner
    IDK??? Both. My dad's is a stick and mine is auto.
  12. Jun 2, 2009 at 1:09 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    hmm...
    What's the diff between the pre-runner and say x-runner 4.0L that requires 0.7quarts more oil in the engine? I don't understand that one bit... I've been running 5.5quarts on my pre-runner, which is dead center on the stick...
  13. Jun 2, 2009 at 6:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2. I dont think that page is all too accurate.
  14. Jun 2, 2009 at 9:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only the Auto has a filter...
  15. Jun 4, 2009 at 10:13 AM
    The_05
    The_05 Active Member
    Waco, Tx
    05 Base Tacoma
    Nothing special at the moment just a K&N air filter.
    My Truck must be the oddball then because its a 2005 Base model 5lug with a dipstick for the trans. and my rearend apparently is not supposed to have a fill plug but it does. Many of those sealed items are not sealed in my truck.:confused:
  16. Jun 4, 2009 at 12:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    All trucks have a servicable rear diff....You have the 4 speed auto, which is not a sealed tranny. :)
