Make an Argument for Manual Trans
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CG3, Aug 18, 2017.
  1. Aug 21, 2017 at 3:00 PM
    #161
    Connecticut_Tacoma
    Connecticut_Tacoma Well-Known Member
    Old Greenwich, CT
    2016 Tacoma TRD SPORT 6-speed Access Cab
    Also another thing to note about manuals. Please I hope people don't take offense and get all worked up like my previous post...
    Only a manual sounds good with an after market exhaust. You can ride the gears through all the sweet spots. For me it's between 3k and 4K RPM. An automatic tends to shift right before you hit all the sweet spots unless you're really gunning it. So yeah if you plan on getting an aftermarket exhaust definitely get a manual.
  2. Aug 21, 2017 at 3:13 PM
    #162
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    I had the 07 ORDCSB and I can tell u it was a blast to drive. In 2013 it was totaled. It was 07 6mt ORDC SB. paid 32,000. 227,000 miles on it. Never replaced the clutch and NEVER a issue. The insurance gave me 19,500.00 for the totaled price. So they hold there value.
    Fast forward to today. It's still a blast to drive. And so much smoother. I'd rather have the 4.0 motor. I do have the 40 series flowmaster with dual exhaust. I did take me 5 months to get the truck I wanted. Do you know why? Because of the manual!! So keep that in mind. All options with the stick was the issue.
  3. Aug 21, 2017 at 3:26 PM
    #163
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    My sport has front and rear lockers. You can always add it.
    It's not a limited slip diff. It's an open diff. The ABS emulates LSD.
    shakerhood likes this.
  4. Aug 21, 2017 at 3:53 PM
    #164
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    True, but I like to leave stuff stock, don't want to go ripping apart a brand new truck.
    ajsabra[QUOTED] likes this.
  5. Aug 21, 2017 at 3:58 PM
    #165
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    It still delivers the same result.
  6. Aug 21, 2017 at 3:58 PM
    #166
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    OK here are my arguments for a manual transmission:
    Easier to service - drain and fill, no dropping pan to change filter.
    Can bump start he engine - if battery and/or starter motor are inopertive
    Fewer heat-related issues, if you tow or haul a lot.
    For the record, I have an automatic :)
  7. Aug 21, 2017 at 4:36 PM
    #167
    specter208
    California
    Frontier S/SV/Pro-4x Crew V6/6spd Manual
    Frontier S King Cab I4/5spd Manual
    Chevy Colorado WT I4/5spd Manual
    RAM 2500/3500 Cummins Diesel I6/6spd Manual
  8. Aug 21, 2017 at 5:54 PM
    #168
    su.b.rat
    su.b.rat broken truck
    and i carefully considered every one of those. then i decided Taco or no go. Frontier wasn't looking too bad for an MT small fun package.
  9. Aug 21, 2017 at 6:03 PM
    #169
    ajsabra
    Sin city
    No it doesn't LSD is controlled by a clutch type system and doesn't slow you down. ABS Grabs the spinning wheel to make the other wheel spin, which slows you down.
  10. Aug 21, 2017 at 6:04 PM
    #170
    ajsabra
    Sin city
    Fair enough ;)
    Riding Dirty[QUOTED] likes this.
  11. Aug 21, 2017 at 6:11 PM
    #171
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Only one of those is really comparable to the taco.
    The 4cyl frontier and Colorado are stripped out fleet trucks only available in 2wd. A 6spd Ram will set you back at least 39k for a regular cab 2wd base model.
    Edit: the Colorado is actually a six speed as well.
    thdrduck likes this.
  12. Aug 21, 2017 at 7:04 PM
    #172
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Plus if I am not mistaken the computer also cuts power to the engine besides the ABS grabbing the spinning wheel.
  13. Aug 21, 2017 at 7:28 PM
    #173
    IndyZen
    IndyZen Well-Known Member
    Marc
    Central Indiana
    2017 Inferno TRD Off Road DCSB 4X4 Manual Tranny
    At the end of the day, you'll have to decide what's best for you by driving both of them...but I chose the 6 cylinder 6speed manual because:
    1. I have always enjoyed driving manuals
    2. Manuals tend to have fewer, and less expensive repairs in my experience
    3. Tacoma is only mid-size that offers higher trim levels in a manual (I liked the Nissan, but it's getting a much needed face lift and a 2017 will likely not hold value well like a new Taco likely will)
    4. The Taco auto did not impress me...odd shift points
    5. The manual ran about $1,600 less than the same trim in auto
    6. I have owned a lot of manuals and autos over the years, there's just no escaping a certain cool factor with a manual
    7. No one has asked to borrow my truck in the 6 weeks I have had it cause few know how to drive a stick.
    8. My wife likes manual trannys too...so she preferred it as well.
    9. The 2017 Taco manual shifts like a dream...not everyone agrees on this site, but I think the gearing and shifting on the stock 6speed is just about perfect for a truck.
    10. Did I mention, I really enjoy manuals and was willing to search high and low to find one with exactly what I wanted.
    Either way you go...have fun, it's a sweet, fun truck that looks badass no matter the tranny.
    Spare Parts, Jeepnick and specter208 like this.
  14. Aug 21, 2017 at 8:19 PM
    #174
    ajsabra
    Sin city
    I beleive your right.
    shakerhood[QUOTED] likes this.
  15. Aug 22, 2017 at 6:19 AM
    #175
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Unless you just really "like" it. What is there that the automatic in S mode can't do that a manual can? I love a manual in sports cars, but I'm over it. Any hint of traffic, and I don't want to screw with a clutch.
    I've been driving my Taco autos in S mode for 12 years without any issues, or break downs. Before that I drove the piss out of a couple of Rangers the same way.
    G.
  16. Aug 22, 2017 at 6:26 AM
    #176
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Cause it obviously gives you a bigger dick to swing - [​IMG]
    IndyZen likes this.
  17. Aug 22, 2017 at 7:26 AM
    #177
    Dc2tacoma
    Dc2tacoma Well-Known Member
    You don't know what traffic is until your life is the 405.
  18. Aug 22, 2017 at 8:31 AM
    #178
    Garyji
    Gary
    My point exactly!
    G.
