Make Sure To Hook Up the Parking Brake Wire!!
Discussion in 'Audio & Video' started by waynea4, Mar 13, 2008.
  1. Mar 13, 2008 at 7:16 PM
    waynea4
    waynea4 [OP] Active Member
    Western N.C.
    Red 08' Double Cab TRD Sport 4X4
    Ok I am gonna add my little piece of advice to all the devoted TW members! I just installed a Kenwood DDX-6019 into my 08' Taco, I purchased the unit from Crutchfield for around $600. All instructions, wiring, and dash kit included ( the kit included was black, so I ordered a silver one from Ebay). Anyway I have put in several head units into vehicles in my past and this install was pretty simple. This is my only advice to anyone who is installing a touchscreen dvd player into their Taco.... I noticed that the Kenwood had a green wire that stated for it to be hooked to the parking brake switch. Well I did not think this was an important step because it did not state in the instructions that it was required to be connected to the parking brake switch for the unit to work. Well I connected all the other connections and put the dash back together, the player worked great, the sound was great and it looked great in the truck ( I will post pics later). The only glitch was that when you played a dvd no picture was present, just sound. Comes to find out the parking brake wire has to be connected before the dvd player will show video. Before anyone slams me about driving and watching movies let me say this, I bought the player so that my wife and daughter can watch movies on those long road trips. I am not going to risk wrecking and hurting someone or my family due to watching a flick. So if you are installing this type of head unit make sure to connect the parking brake wire, now here is how I made my dvd player work while driving. On the Kenwood units the parking brake wire is light green, if you want video anytime connect this wire to a GROUND (negative). Make sure not to connect this wire to a hot (positive) or you will fry your new dvd player. Now be aware that in most states it is illegal to have video playing where the driver can watch. ( I think that most police officers have better things to do than pull people over for a movie playing in the front, but I could be wrong ) I hope this post helps some of you out before you have to pull your head unit back out and hook the wire up like I had to!
  2. Mar 13, 2008 at 7:19 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    yeah, i did the same thing to my pioneer dvd/nav. the newer pioneers require the grounding as well as some soldering on the board
  3. May 14, 2011 at 8:38 AM
    pgiroua
    pgiroua Geaux Tigers
    Royce
    Cypress, TX
    07 PreRunner SR5
    Fog Lights "a la Caribe Style", 20% Tint, csjumper2003's LED's (dome, map lights, park lights), Sylvania ZXE headlights and fog lights, Tonnopro Bed Cover, DTRL on any time mod by piercedtiger, Maxtrac Spindles, Bilstein 5100's (front and back), OME 883 Coils, All Pro Standard Leaf Pack
    Where did you ground yours?
  4. May 14, 2011 at 8:40 AM
    The_Hodge
    SC
    i grounded mine into the chasis ground in the wiring harness
  5. May 14, 2011 at 11:10 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    I think a lot of people would do this except it is beneficial to add a switch of some sort as well.
  6. May 14, 2011 at 4:34 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    The switch is usually due to a quick method or one sans relay. Some units require it not be a constant ground, so the switch method works like putting on your brake - but so does a relay.
    On the pioneer Avic units it is different for different series. The one for the Z110-120 series is by far the easiest method I have ran into.
  7. May 14, 2011 at 5:23 PM
    pinktaco808
    pinktaco808 Hot Steppa
    anyone got pics of the install to the ground and too the e brake
  8. May 28, 2011 at 11:04 AM
    BmacTaco
    BmacTaco Member
    Tampa
    2011 PreRunner TRD Sport
    Thanks for the information. I figured too that not connecting the green wire was a non-issue. But after the fact. I grounded mine, and the videos now work.
  9. Jul 3, 2011 at 10:43 PM
    xroller
    xroller Blowin by em sideways
    X-roller
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    Anyone know which wire it would be on the harness for the parking brake?
  10. Nov 28, 2011 at 8:26 AM
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    X2
    X2
