Make your own underhood light with Rock Light LEDs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tamer, May 23, 2020.
  1. Feb 19, 2022 at 5:28 PM
    #161
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  2. Feb 20, 2022 at 10:06 AM
    #162
    Mayak1957
    Mayak1957 Member
    Tony
    Connecticut
    09' Speedway blue, DCSB TRDOR taco, 6spd Man.
    2WD Low module, Foglights anytime, Ultimate headlight Upgrade.
    id like a set of the universals if there's another run.
  3. Feb 20, 2022 at 4:35 PM
    #163
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
  4. Feb 23, 2022 at 7:51 AM
    #164
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    OK. Here's my take:
    I'd been wanting to do some kind of under-hood lighting for a while now and the OP gave me some good inspiration.
    Now, I don't have a lot of fancy equipment. I can't always make something look perfect and professional, but I can usually make it function as intended even if it is not pretty. I don't have a 3D-Printer or a CNC machine. But I do have a bandsaw, a drill press and a Rivet Nut tool. And a helluva lot of good old-fashioned Yankee ingenuity.
    I had some old industrial plastic that was about ¼ inch thick. So I traced out the lights onto a sheet of heavy paper which I then used as a template to cut the mounts out of said plastic on my bandsaw. I then cleaned them up with some sand paper to make them match the contour of the lights. I then put the plastic mounts into a vise and with the help of a Heat Gun, I warmed up the mounts enough that I could bend the tabs over at about a 45 degree angle. Then off to the drill press. Sorry, but I should have taken a picture of the brackets before I installed the lights on them. But here's a closeup.
    To mount them to the hood I installed a couple of small Rivet Nuts into some existing holes under the hood and bolted them up with a little bit of Locktite to hold them in place.
    Wiring was pretty straightforward. I decided to use a manual switch (not pictured) instead a pushbutton switch operated by opening the hood. The finished product:
  5. Feb 23, 2022 at 11:07 AM
    #165
    RunUp
    RunUp Well-Known Member
    genius
  6. Feb 27, 2022 at 1:33 PM
    #166
    Tech96
    Tech96 Active Member
    Bill
    Texas
    14 Tacoma DC
    Looks good. How rigid is the plastic?
  7. Mar 5, 2022 at 4:39 AM
    #167
    Tactical_Panda
    Tim
    Fredericksburg, VA
    About 1/4-inch thick.
  8. Mar 5, 2022 at 5:44 AM
    #168
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    So , there is no wire splicing, right? I was wondering about this until the video posted. Is this true regardless of which light is chosen? I would love to do this along with the anytime fog light mod.
  9. Mar 5, 2022 at 1:01 PM
    #169
    Jeff Dartfrog
    Jeff Dartfrog Well-Known Member
    Jeff
    Chandler AZ
    2019 Cavalry Blue TRD Off Road
    I think I made the most expensive DIY underhood light ever!!!! I had to use nylon nuts because metal hardware created a ground connection and the lights stayed on always!
    IMG_2109.jpg IMG_2110.jpg made!
    jbroadwater, Pyrotech and SiskYota07 like this.
  10. Mar 15, 2022 at 3:35 PM
    #170
    Tech96
    Bill
    Texas
    14 Tacoma DC
    @Jeff Dartfrog How do you like that AFE set up? I have one on order and it is a 14 week lead time.
  11. Mar 15, 2022 at 3:37 PM
    #171
    Tech96
    Bill
    Texas
    14 Tacoma DC
    I made some with Simpson tie brackets and ProComp rock lights I had laying around.
    kgarrett11 likes this.
  12. Mar 15, 2022 at 4:37 PM
    #172
    Jeff Dartfrog
    Jeff
    Chandler AZ
    I like it fine. I ran aFe intakes on my 3-series BMWs before I got into Toyotas. After I bought my first Tacoma I was excited to learn they made an intake for it. My butt dyno says it makes a difference!
  13. Mar 15, 2022 at 5:35 PM
    #173
    Tech96
    Bill
    Texas
    14 Tacoma DC
    Cool thanks I can’t wait to get mine.
    Jeff Dartfrog likes this.
  14. Mar 18, 2022 at 12:44 PM
    #174
    Pyrotech
    Pyrotech Well-Known Member
    I can do a set of two aluminum brackets powder coated matte black with mounting hardware for $45.00 plus 9.45 flat rate usps priortt mail small box
    pm for ordering details, if interested
    1. @jarebear74
    2. @JasonLee
    3. @BuzzMor
    4. @Midship909
    5. @ianGP
    6. @sf.larry Shipped
    7. @Sl3ven
    8. @TacomaOH
    9. @Yamahafast
    10. @Cbaxter617
    11. @Squirrel13
    12. @79CHKCHK Pending
    13. @dmrivera78
    14. @#NEVERGIVEUP
    15. @audiopudding
    16. @TacO1O
    17. @elmontemike
    18. @Uthmoelleri
    19. @FastEddy59
    20. @daveeasa Shipped
    21. @lizoid
    22. @mac84
    23. @Dr3w
    24. @TacoBlacko12
    25. @rb9228
    26. @Jahjahsoljah
    27. @25TacomaDCab25
    28. @Gunerbey
    29. @Tacoma_702
    30. @BlkTaco20
    31. @esgar18
    32. @LitFuse
    33. @big42mac
    34. @shleppy
    35. @Chuy21
    36. @flatt-taco15
    37. @tmzphoto
    38. @Camel89 Pending
    39. @Sirnick88
    40. @taco_OnTheMove
    41. @pearing Shipped
    42. @kaijac03 Shipped
    43. @Mayak1957 Shipped
    44. @Tcpetty58D Shipped
    45. @audiopudding Shipped
    46. @nickac1092 Shipped
  15. Mar 18, 2022 at 2:19 PM
    #175
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    Will these be the same design as OP just Al? And which design? Preferably it's the universal design from OP.
  16. Mar 18, 2022 at 2:29 PM
    #176
    Pyrotech
    here is the 3d printed prototype it is slightly different, but does have a center mounting hole, I do not have a set of the KC cyclones to test fit, for verification.
    the 4 hole just off center from the the end is to pass the wire through on the Amazon rock light
    daveeasa likes this.
  17. Mar 18, 2022 at 11:51 PM
    #177
    audiopudding
    audiopudding Well-Known Member
    Republic of Cascadia
    2017 Inferno Tacoma Off-Road DCSB
    AVS in channel rain guards Bed matt Roof rails 3m Vinyl wrapped hood and mirrors Removed TRD Off Road bed stickers Snugtop Rebel canopy matching color http://www.snugtop.com/product/rebel Navigation screen protector https://www.amazon.com/gp/product/B073LM7KM4 A/C Drain mod fix Thanks to @Uptown2k https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ Bed cubby covers Thanks to @micwillia https://www.tacomaworld.com/threads/bed-cubby-covers-for-sale.491909/ Extended height fuse cover Thanks to @mesojdm (who will be thanks a lot, by a lot of people) https://mesocustoms.com/collections/toyota-tacoma-3rd-gen/products/extended-fuse-cover Ultimate Map Lights Thanks to @mesojdm https://mesocustoms.com/collections/toyota-tacoma-3rd-gen/products/ultimate-map-lights Ultimate Dome Light Thanks to @mesojdm https://mesocustoms.com/collections/toyota-tacoma-3rd-gen/products/ultimate-dome-light Total Tail Stage 1 Thanks to @mesojdm (wired my own but bought his for his for the custom designed switchback t10) https://mesocustoms.com/collections/toyota-tacoma-3rd-gen/products/stage-1-3rd-gen-tacoma Ultimate LED turn signals Again, thanks to @mesojdm https://mesocustoms.com/collections/toyota-tacoma-3rd-gen/products/ultimate-turn-signals Center console tray https://www.amazon.com/gp/product/B01KI3WG1O Truck bed header rail https://www.amazon.com/gp/product/B00DWVN9CK Total Chaos bed stiffeners http://www.chaosfab.com/2016-2017-Tacoma-Rear-Channel-Bed-Stiffeners-48676
    Nicely done. However any reason why the neck is longer than the OP's in your prototype?
  18. Mar 20, 2022 at 7:46 AM
    #178
    Tcpetty58D
    Tcpetty58D New Member
    Tacoma, WA
    2022 Tacoma TRD Pro
    @pryotech, put me down for a pair also
  19. Mar 20, 2022 at 4:05 PM
    #179
    audiopudding
  20. Apr 1, 2022 at 12:11 PM
    #180
    Pyrotech
    Progress Update:
    I received the parts from my vendor a couple days ago, however due to my work schedule where I work out of town for 8 days straight, today is the first day I am able to work on completing the brackets.
    Everyone who has paid so far there brackets are in the production as I type this, all of them have been Bent, and the first QC check down to verify the angle, ( being done by a manual brake there will be some deviation +/- a couple degrees is my target) and the final tab measured to make sure it is again close to the spec. ( I did catch my backstop sliding out of position this way).
    The powder coat oven is running a new auto tune to verify its setting after using the oven to stabilize some wood blanks for a future project(s). The parts should be ready to go in the oven later tonight or first thing in the morning.
    I want to take a moment and thank each and everyone of you who bought a set of brackets already, knowing that there would be a delay of a couple weeks, between ordering and getting your order. I take your trust seriously and my goal is to provide a quality part for your truck, one I would be proud to have on my own vehicles. Thank You !
    Some pictures because who doesn't like pictures?
    Mayak1957, Nubes and daveeasa like this.
