Makerbot 3D Scanner
Discussion in 'Technology' started by Evil Monkey, Mar 13, 2013.
  1. Mar 13, 2013 at 11:55 AM
    Evil Monkey
    Evil Monkey [OP] There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Makerbot is coming out with a 3D scanner that will allow you to scan in an object which can then be printed on a 3d printer without requiring the user to design it in a cad program. Cost will be around $2000-$3000
    http://mashable.com/2013/03/08/makerbot-digitizer/
  2. Mar 13, 2013 at 12:43 PM
    RAT PRODUCTS
    RAT PRODUCTS RAT Products
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    I've used handheld 3d scanners for reverse engineering and measurement, and honestly most suck for anything more than a couple components. They get very confused on arcs and most times put in splines instead of lines or arcs. Splines are a no go when you are making laser, cnc, or dimensioned patterns. It takes more time to redo the splines than dimensioning by hand in most cases. This one is for small parts so I'm sure it would be more accurate, but it wouldn't work for anything I've scanned. For the industrial parts I dealt with we now use a CMM.
  3. Mar 13, 2013 at 4:05 PM
    Evil Monkey
    Robert
    Escondido, CA
    These are more intended as hobbyist tools. The replicator and the scanner would run about $5K total.
  4. Mar 13, 2013 at 7:07 PM
    RAT PRODUCTS
    Farmington, MN
    Makes sense. Spendy little contraption but I'm sure it's nice.
