Making 32's or 33's fit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by unccpathfinder, Dec 28, 2011.
  1. Dec 28, 2011 at 1:24 PM
    unccpathfinder
    unccpathfinder [OP] Member
    Sparkle City, SC
    08 SR5, Double Cab, v6, 6 sp MT
    I apologize if this is a beaten horse...I've searched and not really found the answer so if its out there and someone wants to post a link I don't mind reading...
    Basically I want to put 32's or 33's on my 2008 double cab...this is a daily driver and don't really have plans to wheel it hard as I have a trail truck for that.
    What I have in mind is a performance accessories 3" BL since its about the most reasonably priced option and least impact on c.g. height increase.
    So my questions:
    1) will the 3" BL allow me to clear 32s or 33s without any body trimming? If i need to trim how severe for mild offroading?
    2) is it possible to change tire size in the ecu to get correct speed and mileage output or gear changes for the speed sensor?
    3) can I use 15" wheels or is the brake package going to prevent anything under 16" wheels? As I have wheels/tires off my trail rig that I'd run on my taco if 33s will fit
    I have read the PA instructions and none of that seems too challenging...
    Thanks in advance
  2. Dec 28, 2011 at 1:27 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Body lift wont do it, you wont clear the upper control arms. You need to get a suspension lift as in coils, or preloadable shocks, such as the Bilstein 5100's.
  3. Dec 28, 2011 at 1:32 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    no 15" on these 6 lug trucks,will rub the caliper.32s fit on stock truck.in order to go to a 33" you need a 3" suspention lift with some trimming
  4. Dec 28, 2011 at 2:28 PM
    unccpathfinder
    Sparkle City, SC
    See the issue with the Uca...anyone run wheel spacers to clear...I'm not a huge fan of them but survived moab Utah with them so i think they'd be okay for my DD
  5. Dec 28, 2011 at 2:58 PM
    CentralFlaTaco
    CentralFlaTaco Active Member
    Scott
    North Central Florida/Ocala National Forest
    2011 Regular cab 4x4 4cyl 5spd
    Front brush bar, 4" side nerf bars, Bak Bakflip G2 bed cover, tail light cages, 3" Old Man Emu full suspention with 885 front and rear Dakar leaf springs, 3 degree rear axle shims, 8" Sound Ordinance powered subwoofer, Light Racing UCA, DeeZee bed mat
    Pataco, I saw you said 32's will fit on a non lifted 4x4. I have a 2011 reg cab 4cy 4x4 base, do you think a 32 will fit on there with no lift ? my 32 x10.25 wheels and tires are in at the tire store and OME lift on the way but would like to pick up wheels and tires now before installing lift
