making a wierd wining noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeeezy, Apr 28, 2011.
  1. Apr 28, 2011 at 2:30 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    07 dbc long box speedway blue
    custom cold air intake 4 inch tubing, MBRP dual catback exhaust, readylift leveling kit with 265/75-17 on eagle alloy rims
    after taking my truck to play in the mud yesterday now it has a wierd wining noise, almost like it has a supercharger haha my buddies were telling me its my power steering pump what do you guys think?
  2. Apr 28, 2011 at 2:31 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    umm it would be a crappy cellphone vid though, and im stuck at work
  3. Apr 28, 2011 at 2:34 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    If your at work, what the hell are doing on TW? Haha jk. When your driving or idling?
  4. Apr 28, 2011 at 2:35 PM
    toytaco1
    toytaco1 Well-Known Member
    jed
    moreno valley
    05 supercharged trd off road
    trd supercharger, TRD intake, magna flow exhaust, JBA headers, walker evans front, fox rear, leaf pack, drilled slotted rotors, All Pro Front Bumper, Warn 8000 Winch
    Probably got mud on your belst try giving it a good cleaning, or try taking off your serp belt if the noise goes away it is your belt
  5. Apr 28, 2011 at 2:40 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    its all the time the truck can be idling and it still wines it gets louder when u give it gas, and yes im at work on TW im addicted lol
  6. Apr 28, 2011 at 5:53 PM
    chillindrdude
    chillindrdude Member
    Neil
    DC metro
    06 Toyota Tacoma TRD
    my 2006 is making a similar noise i think. the whinning/whirring gets worse as speed increases or when you gas it. i can sense a small amount of vibration in my feet while driving which also increases as the speed increases. seems to be coming from the front center right of the underside of the truck. saw a few drips coming from that area too.
    any engine wizards can deduce what is going on? the whirring sounds like the 4wheel drive is engaged.
  7. Apr 28, 2011 at 5:54 PM
    fortyniner
    fortyniner Active Member
    Seattle
    08 tacoma 4x4
    I would start by opening up the hood and sticking my head under there and see if I could detect where the noise was coming from. Sometimes you can take a piece of hose and put it to your ear and move the other end around the engine and see if you can isolate the noise. Just a thought.
  8. Apr 28, 2011 at 6:14 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    ok made the vid im guna try and post it, not to sure how to do it so bear with me on this one
  9. Apr 28, 2011 at 6:16 PM
    chillindrdude
    Neil
    DC metro
    from some related threads here on TW, i think it may be my front differential...calling the dealership tomorrow.
  10. Apr 28, 2011 at 8:33 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
  11. Apr 28, 2011 at 9:31 PM
    ayunk04
    ayunk04 Well-Known Member
    Adam
    Pittsburgh
    trd off road
    6 inch pro comp
    I have the same exact sound in my 05 after i took it mudding couple weeks ago.
  12. Apr 28, 2011 at 9:33 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
  13. Apr 28, 2011 at 9:47 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    could it be the power steering pump? or does it sound like belts?
  14. Apr 28, 2011 at 9:49 PM
    ayunk04
    Adam
    Pittsburgh
    trd off road
    6 inch pro comp
    Mine sounds like belts
  15. Apr 28, 2011 at 9:52 PM
    Superx2
    Joey
    Iowa
    that dont sound like belts to me. when it idles down it sorta sounds like power steering.
  16. Apr 28, 2011 at 9:58 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    ive been working quite a bit lately but tomorow im going to pop the hood and see if i can source out were the sound is comming from
  17. Apr 28, 2011 at 10:10 PM
    Superx2
    Joey
    Iowa
    come on! if your on TW during work, then you are on TW not working. ;) (i only get on during lunch.) giving you a hard time dude! i actually have tomorrow OFF!!!!! good luck w the truck. let us know what the noise was.
  18. Apr 28, 2011 at 10:15 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    It's definitely your belts, and that's exactly why I don't blast through mud anymore.
  19. Apr 29, 2011 at 7:34 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    its just mre fun that way :p
  20. Apr 29, 2011 at 8:57 AM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
    Idler bearings, I had to replace two of mine last spring. It was making the same kind of noise as your truck, kind of sounded like I had a supercharger.
    Going from memory here, the 4.0 has 2 upper and 2 lower idlers plus a tensioner. I ended up replacing both upper idlers. I found them at www.rockauto.com for like $35 a piece, Toyota wanted like $75. I tried to source just the bearings at the local hardware store, but had no luck.
