Making an anti-lean spacer for 5100's??
Discussion in 'Suspension' started by BenWA, Jan 23, 2011.
  1. Jan 23, 2011 at 8:49 PM
    BenWA
    BenWA [OP] Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    I was thinking about making a spacer for my driver's side 5100 to counter the Taco lean.
    My idea was to turn (on a lathe) a piece of round stock into a 1/4" long sleeve that would slide over the strut body and sit on the C-ring that the lower coil stop rests on. Basically, the sleeve would have the same outside diameter as the outer edge of the C-ring.
    I'm no mechanical engineer, so is there any reason why this would be a bad idea or would be prone to failure for any unforseen reason?
    On another note, if you ask me, I think that 5100's should have twice as many C-ring grooves as they do, all at roughly 1/2" intervals so that you can mix and match the height settings asymmetrically on either side of the truck to counteract the lean if so desired. In other words, rather than just have .85", 1.75", and 2.5", they should have .85", 1.3", 1.75", 2.125", and 2.5" or whatever
  2. Jan 23, 2011 at 8:55 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    toytec makes a 1/4'' spacer for just that reason. it's only $20
  3. Jan 23, 2011 at 8:56 PM
    AvsFanTRD
    Brandon
    Wyoming
  4. Jan 24, 2011 at 10:05 AM
    kramer2k
    kramer2k Well-Known Member
    Jacksonville, FL
    08 DC PreRunner TRD OR
    I just ordered one of those to go with my 5100 installation in a few days.
    Side note: where exactly do I install the 1/4" top plate spacer? I'm looking for a clear picture but I've come up empty so far. (I'm a suspension dummy)
    I think it's a pretty simple piece of metal, so making one would be fine IMO. If you can beat the price of $20 plus $11 shipping I say why not.
  5. Jan 24, 2011 at 10:42 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    It goes above the top plate on the shock assembly. It's the last thing you put on before the shocks go back on the truck.
  6. Jan 24, 2011 at 10:52 AM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    so no need to take apart the strut assembly? the lean on my truck is really starting to bother me! my friends constantly point it out and make fun :mad:
  7. Jan 24, 2011 at 10:54 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    if reusing the stock coils with 5100s, should be no need for a spacer as the coils are side specific to correct the weight offset.
  8. Jan 24, 2011 at 11:00 AM
    kramer2k
    Jacksonville, FL
    Ahh, I see. I can picture that. Thanks
    Same here. My buddy always points it out and jabs me about it. No more though after this weekend! :D
    For real?! This is the first time I've heard this.
  9. Jan 24, 2011 at 11:01 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Not true. I had lean before installing 5100s with stock springs. After the 5100s and a 1/4" spacer I am now level.
  10. Jan 24, 2011 at 11:06 AM
    TexasTacoma37
    Correct. :thumbsup:
  11. Jan 24, 2011 at 11:09 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    cool thanks... you think i would i need an alignment afterwards?
  12. Jan 24, 2011 at 11:25 AM
    Bama_TACO
    Winfield, AL
    Yes, alignment would be needed. You may not change it much by just installing the spacer, but it will change it some.
  13. Jan 24, 2011 at 11:30 AM
    BenWA
    Boston burbs
    Yeah, that was something that confused me -- how the stock coils are slightly different lengths. But nonetheless, I had/have a 1/2" lean before and after installing 5100's, so I want to level the lean with a spacer.
    Sounds like the top plate spacer is easier than my homemade idea.
  14. Jan 24, 2011 at 11:34 AM
    RCBS
    i have an '06 off road and the coil springs are color coded for left and right sides...had to be careful not to mix them up when i put 5100s on...i have no noticable lean.
    Sport springs & SR5/base not side specific, maybe? :notsure:
    i am 99% sure that mine are.
  15. Jan 24, 2011 at 11:35 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Mine has a little lean on stock coils. I need to add a spacer to the driver's side.
  16. Jan 24, 2011 at 11:38 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    i had no lean with my stock coils. i got a lean after i installed OME 885's.
  17. Jan 24, 2011 at 11:38 AM
    Bama_TACO
    Winfield, AL
    Good point. That may be the case.
  18. Jan 24, 2011 at 3:28 PM
    RCBS
    Wheeler's offroad has "trim packers" that are the same thing for less than $8.
  19. Jan 24, 2011 at 11:16 PM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    I'm running OME 885s with OME N140S struts... Thankfully Chris4x4 saved me with his milled down 1/4 spacer. Thanks homieee!
  20. Jan 25, 2011 at 8:32 AM
    macgyver
    Brad
    Canton, GA
    Those are for OME shocks though. Does anyone know if these work on the bilsteins? Is the shock tube diameter the same?
