Making an emergency whole house generator out of 3rd Gen Tacoma?
Discussion in 'Garage / Workshop' started by Sequoia1321, Oct 28, 2019.
  1. Oct 29, 2019 at 8:05 PM
    #81
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    This guy knows how to have a good time.
    stun gun likes this.
  2. Oct 29, 2019 at 8:06 PM
    #82
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Is it Friday in Kiribati yet?
  3. Oct 29, 2019 at 8:07 PM
    #83
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    You ever hook your laptop battery up to your bicycle just so you can watch a few minutes of porn? That's some wicked torture there, man.
    MattCowsmasher, stun gun and tcjacado like this.
  4. Oct 29, 2019 at 8:07 PM
    #84
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Idk but if you found one of those people with a 3rd nipple, we could wire them up to run 3 phase.
    jowybyo[QUOTED] and Rock Lobster like this.
  5. Oct 29, 2019 at 8:08 PM
    #85
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    Malvolio likes this.
  6. Oct 29, 2019 at 8:10 PM
    #86
    toyodajeff
    jeff
    06 reg cab sr5
    I guess according to osha rules well have to wear arc flash gear to check his nipple volts.
  7. Oct 29, 2019 at 8:12 PM
    #87
    toyodajeff
    jeff
    06 reg cab sr5
    When I used to work in industrial maintenance I watched a video about arc flashes similar to that one and it really messed with my head for a while.
  8. Oct 29, 2019 at 8:12 PM
    #88
    computeruser6
    Dirk
    Escondido
    Maybe. Maybe these guys could've used arc flash gear though:
    https://www.youtube.com/watch?v=ObevFZMohuA
  9. Oct 29, 2019 at 8:15 PM
    #89
    toyodajeff
    jeff
    06 reg cab sr5
    I ain't gonna watch them. Seeing one dude on fire is enough for my lifetime. I saw the one about the guy in some sawmill using s 600v meter on a 2300v wire
  10. Oct 29, 2019 at 8:18 PM
    #90
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I only practice lock-out-tag-out. Hope his nipple rings can take a masterlock.
    0xDEADBEEF likes this.
  11. Oct 29, 2019 at 8:25 PM
    #91
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    This is funny as hell. But I'm home sick with nothing else to do, so why not..
    Cheap? No. Rigged up? Maybe..?
    Let's start at the beginning. How do we get the power from the truck engine to the generator? Disconnect the drive shaft and rig something small the sits under the truck to redirect the power to the generator.. maybe a belt system? Will need a custom driveshaft for this. Something thats the right length and doesnt interfere with the carrier bearing or rear end. Should also keep in mind the angle of the u-joints. Or we just use the rear wheels. Neither of those sound even remotely safe imo. Id be looking for a chassis dyno-style setup if using the wheels. Or lots of wheel chalks and guarding for the prior method. Or maybe we go right to the flywheel of the engine? :facepalm:
    Ok so now we got that figured out, from there it cant be too hard to get the power to the generator itself. A sturdy frame for everything to sit on and gear box of some sort will do nicely. But wait, what ratios? Well that depends on where we are hooking in. Generally speaking 60hz power (USA) is generated by spinning the genset at 3600 rpm EXACTLY. While our setup doesnt have to be exactly 3600, you will see your lights flicker if it fluctuates at all and isnt really great for some electronics to be more than a few Hz away from 60.
    Hmm well ok, what gear is the transmission going to be in? AT or MT? If an AT is the torque converter locked up or not? If using the rear wheels we also need to consider the ratio of the rear end as well as everything else.
    Ok we found ratios that work. Or did we.. After all this math is done, what is the engine RPM? Does it make the required power at that RPM (hp to kW)? Did we account for drive train losses?
    Now we get to the fun stuff. How to control the engine rpm.. Arduino controller with a linear actuator on the gas pedal and an RPM sensor on the genset is the first thing that comes to mind. But I have no idea how that would work or if it would be quick enough to react to the changing loads of the house. Maybe we add a friggin uge flywheel to the genset and hope theres enough rotational inertia to absorb any changes in load? Maybe we go full send with a mechanical governor on the genset and a linkage all the way back to the gas pedal? (that would be the coolest, but neither cheap nor "rigged")
    Maybe we say all this is :crazy: and we rectify the output of the genset to DC, filter it, and run it through inverters back to AC at whatever voltage / Hz we want. But now we just made things super expensive and also decoupled the system, so the fluctuating loads may have an even bigger impact now.. would depend on the equipment used.
    Of course this doesnt consider the simple stuff like the gas needed to run the truck at roughly one RPM for hours on end. Or any of the ATS equip needed to safely tie it into the entire house. Or the work needed to get it all setup. But hey, still kinda interesting
  12. Oct 29, 2019 at 8:32 PM
    #92
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    So you’re saying there’s a chance!
    whatstcp and stun gun like this.
  13. Oct 29, 2019 at 8:32 PM
    #93
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Its definitely possible to rewind an automotive alternator to output 120vac ( https://www.qsl.net/ns8o/welcome.html ).
    Whether its a good idea is a whole other discussion - but I checked my practicality at the door...sooo...
    I wonder how many electric eels you could fit in the bed?
    tcjacado and stun gun like this.
  14. Oct 29, 2019 at 8:52 PM
    #94
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Whatever. I’ve finished on a bike.
    Rock Lobster[QUOTED] likes this.
  15. Oct 29, 2019 at 8:53 PM
    #95
    stun gun
    Aaronski
    Tacomas.
    Ok that’s nice but now I have to go to Walmart so put the drive shaft thing back in I gotta go
    tcjacado likes this.
  16. Oct 29, 2019 at 8:58 PM
    #96
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
  17. Oct 29, 2019 at 9:01 PM
    #97
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Oh, this is interesting.
    And it’s not even Friday yet.
    Hole EE Fook!
    MattCowsmasher likes this.
  18. Oct 29, 2019 at 9:02 PM
    #98
    jpneely
    Charleston, SC
    its my Friday :D
  19. Oct 29, 2019 at 9:02 PM
    #99
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    How the hell do you think modern helicopters, Naval ships and turboprop planes work?
  20. Oct 29, 2019 at 9:02 PM
    #100
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Let alone an automatic transmission.
