Making bed cubby water tight?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wayne0, Nov 2, 2021.
  1. Nov 2, 2021 at 3:33 PM
    wayne0
    wayne0 [OP] Well-Known Member
    I keep my hitch draw bar and convert-a-ball kit in there, and it's getting rusty. Any easy way to keep water out? TIA.
  2. Nov 2, 2021 at 3:36 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I usually wrap stuff in bubble wrap whenever I put stuff in there
    Skidog1 and Steves104x4 like this.
  3. Nov 2, 2021 at 3:52 PM
    Clearwater Bill
    Billy
    Largo Florida
    Zip lock bag
    shakerhood, auskip07 and Mark77 like this.
  4. Nov 2, 2021 at 4:26 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Nothing that's foolproof unless you vacuum bag it with a desiccant inside.
    Kinda defeats the purpose of having it readily accessible.
  5. Nov 2, 2021 at 4:29 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    FB38AD4A-8C8A-4697-9890-921A5E076051.jpg I’ll have to do this, thank you very much
  6. Nov 2, 2021 at 4:31 PM
    DanoTay
    DanoTay Well-Known Member
    Victoria, B.C.
    2019 Tacoma OR AC MT
    Duct tape.
    Steves104x4 likes this.
  7. Nov 2, 2021 at 4:39 PM
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
  8. Nov 2, 2021 at 4:42 PM
    Stxxx
    Stxxx Well-Known Member
    2009 Tacoma TRD
    andagi808 and mtip like this.
  9. Nov 2, 2021 at 6:18 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Sticky tape foam "weather striping" seems to work quite well.
    I put two pieces side by side over the cover tab and locking tab holes. The cover tabs slide between. Spreading the gap a bit. Not perfect, but "better is the mortal enemy of good enough".
    For the weep holes, I did the same. Two short pieces side by side with the join line centered on the weep hole. I flexed open the crack with a small screw driver just enough to see light. Any water appears to get out OK, maybe slower, but I can't tell.
    It's only been over the summer, and I don't drive much. But so far, it's working.
    Cost is about zip, as I had the foam door and window seal on hand.
  10. Nov 3, 2021 at 5:23 PM
    wayne0
    I guess I'll just pull the puppy out and find something that will seal the holes. I have a bed cover, so it's the water getting in through the "drain holes".
