making bigger diff droppers
Discussion in '1st Gen. Tacomas (1995-2004)' started by houndsmen, May 5, 2011.
  1. May 5, 2011 at 6:35 AM
    houndsmen
    houndsmen [OP] Well-Known Member
    I recently put on a Toytec coilover lift on my 2001 Tacoma, well the front sagged some because of a bumper that I have on it. So I turned them up a few turns, they are still bout 1/2" from being maxed out. I put the diff droppers that came with it but my CV axles have a pretty heavy angle on them and one of the boots already tore..... And when I engage the four wheel, my truck holds back because of the angle and when its in four-low and turned all the way it has a pop..... I am wondering if I can put some bigger diff droppers? I am a machinist and have already drawn up some new ones that I am planning on making. They are about 1" bigger..... Is this possible????
  2. May 5, 2011 at 6:38 AM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    I dont think you can go that big because then when the suspension droops down the cv may come in contact with A-arm
  3. May 5, 2011 at 6:53 AM
    houndsmen
    OH!!!!! Do you have any suggestions on what I can do????
  4. May 6, 2011 at 8:59 PM
    The Munster
    The Munster I like turtles!!!
    Lance
    Moody AFB, GA
    I also noticed on my diff drop (1") my actuator for my ADD is really close to the crossmember
  5. May 6, 2011 at 9:28 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    sadly doesn't appear to be a way to solve the CV problem. Wish it was..would be and easy way for sure!
    But i am also interested in what you would do to help the angles.
    Aftermarket UCAs?
  6. May 6, 2011 at 9:37 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    The only thing that can solve this issue is to utilize a drop bracket lift.
  7. May 6, 2011 at 9:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well drat..
  8. May 6, 2011 at 9:49 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    you can always SAS that thing!
  9. May 6, 2011 at 11:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    HAHA! true that man
  10. May 7, 2011 at 8:13 AM
    350TacoZilla
    Hancock MD
    or long travel ifs using the longer tundra shafts, even at same lift height the longer shaft will have less angle on it.
    but yeah I think 1"-1.25" maybe would be max drop , if you are running a off the shelf lift and havent tried to get more lift out of it then the 1" drops provided should be plenty
  11. May 7, 2011 at 8:17 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    id tone down that lift you got an see about lowering the read a little bit if you can to make it level.. youve torn a boot and your cv's are "popping" i think you probably damaged something and i would reduce the chance of damaging it anymore cause your gunna be forking out more money for repairs if you keep it up..
  12. May 7, 2011 at 10:08 AM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Diff drop..................... Sigh. Gay, just wheel the truck. If it breaks, fix it and wheel it harder.
