MAKING CIRCULAR FRONT BRAKE LINES
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paulrv6, Apr 15, 2025.
  1. Apr 15, 2025 at 12:12 PM
    Paulrv6
    Paulrv6 [OP] Well-Known Member
    paul
    2005 Tacoma
    I have to replace the front steel brake line that goes from the tee to the ABS module. It's not available from toyota so I need to make my own. What is the best way to bend all those expansion circles (their abour 2.5" dia) in the brake line?
    Is there a particular type of brake line that bends easier than others and where is the best place to get it?
    What size are the threads also. Thank you for the help.
    paul
  2. Apr 15, 2025 at 12:14 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Probably going to want to visit youtube and brush up on making brake lines. It is pretty simple and the tools to do it are cheap but you will want a line bending tool and a decent flaring tool. Other than that you will need to get some line and ends from any local auto store. Make sure you put the fitting you need on the line before flaring the end.
    Most importantly, buy extra stuff. You will fuck up twice any many as you are trying to make.
    reallifedog, lowmower and BabyBilly like this.
  3. Apr 15, 2025 at 1:00 PM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    I've had great experiences with nicopp line. Bends super easy, even by hand, and always flares nice with way less effort than steel and supposed to be more corrosion resistant. I buy it from Amazon in like 25 ft rolls from 4lifetimelines, usually overnight or next day shipping. Some auto parts stores have it too but prices are usually higher. Fittings on amazon as well in stainless steel from the stop shop.
    lowmower likes this.
  4. Apr 16, 2025 at 4:00 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    The NiCu lines are ABSOLUTELY more corrosion resistant, and also nicer to work with. It's not worth using anything else where I live in Salt Hell.
  5. Apr 16, 2025 at 6:15 AM
    Paulrv6
    paul
    2005 Tacoma
    Ok thanks for your input guys. What type brake fluid should I put in, dot 3 or 4 or doesn't it matter? Thanks kindly.
  6. Apr 16, 2025 at 9:12 AM
    Peter603Taco
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    If you aren't having boiling issues (sure hope not with a tacoma lol) DOT3 is generally the better choice. You wouldn't damage anything but DOT4 has a higher boiling point, helpful in track cars or higher performance braking but at the tradeoff of absorbing moisture faster therefore needing more frequent flushes.
  7. Apr 16, 2025 at 11:05 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    DOT 3 is the way to go on our trucks.
  8. Apr 16, 2025 at 11:08 AM
    Paulrv6
    paul
    2005 Tacoma
    Thanks guys.
    On to my next problem.
