Making storage in your bed?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ChewbacaTW, Sep 6, 2011.
  1. Sep 6, 2011 at 12:56 AM
    ChewbacaTW
    ChewbacaTW [OP] My progeny will be awesome!
    Sam
    Flagstaff, Arizona
    02 Xtra Cab TRD off road
    K&N air intake, custom exhaust, Powerslot Brakes, urethane steering rack bushings
    Hey I have an idea to put a false floor in the bed of my truck right above the wheel wells and putting a trap door or something on it so I can put gear and what not in there and still have a flat floor so i can still throw stuff in there or throw a futon mattress or something like that so i can sleep in the bed.
    Has anyone else done anything like this? I'm looking for ideas.
  2. Sep 6, 2011 at 1:13 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  3. Sep 6, 2011 at 1:18 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    I've thought about removing the spare and making a storage compartment there. Then a trap door in the bed to access it. I just haven't had the guts to try it...
  4. Sep 6, 2011 at 4:27 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I have seen posts on this before. It involved 3/4" plywood, carpet, and center supports.
  5. Sep 6, 2011 at 4:36 AM
    PreRunner03
    PreRunner03 Hail State
    03 PreRunner Double Cab TRD
    This. OP, try searching sleeper platforms. That might work out.
  6. Sep 6, 2011 at 6:42 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    2nd Gen but you get the idea... It's 3/4" plywood sitting on 2x6's and there are 2 removable panels all the way in the front so you can get to things that slide to the front of the bed without crawling under the platform.
  7. Sep 6, 2011 at 10:42 AM
    ChewbacaTW
    Sam
    Flagstaff, Arizona
    Thanks for the help.
    This is what I was thinking of doing.
    The red is all the hardware. hinges and handles and what not. the handles will most likely be sunk into the plywood.
    The green things are the 4x6 supports that keep the floor from bending under load.
  8. Sep 6, 2011 at 1:55 PM
    tacomazach
    tacomazach Well-Known Member
    Zach
    Mississippi
    01 doublecab 4x4
    Here's a couple pics of mine, just throwing it out there.
  9. Sep 6, 2011 at 11:16 PM
    ChewbacaTW
    Sam
    Flagstaff, Arizona
    thanks Zack and Mike, those give me some other good ideas.
  10. Sep 7, 2011 at 1:53 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
  11. Sep 7, 2011 at 1:57 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    The Honda ridgeline has a really awesome storage unit under the bed, might try searching for images on that for some ideas. Please post some pics of what you come up with.
