Making sure I got everything I need for my lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madams, Apr 2, 2011.
  1. Apr 2, 2011 at 7:46 PM
    Madams
    Madams [OP] Well-Known Member
    South Carolina
    They call it barney
    Done decided to go with the 5100's for my tacoma. I got rear aal, going to get the front shock replacement bushings and washer kit for the front shocks for 5100's. Do I need front diff drop kit and the brake proportioning valve bracket? When I get the 5100's and they not set on 2.5 inch in the front, can I set them on 2.5 inch in the front myself if so, how can I adjust them to that height?
  2. Apr 2, 2011 at 7:54 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Do you have a 4x4 or prerunner? Won't need a diff drop unless you have 4x4.
    The shocks will come disassembled and you can set them to any height you like. you will need a spring compressor to put them together though....
  3. Apr 2, 2011 at 7:58 PM
    Madams
    South Carolina
    They call it barney
    Got 95.5 toyota tacoma sr5 v6 4x4 but read on here some people did just fine with out the diff drop and dont need it just for 2.5 inches of lift. But do i need the brake portioning valve bracket from toytec.
  4. Apr 2, 2011 at 7:59 PM
    KPT
    09 Prerunner
    Never heard of a brake bracket.....The diff drop is cheap and it actually helps your angles on a first gen.
    they are useless on 2nd gens, that's probably what you were seeing when people said not to get one.
  5. Apr 2, 2011 at 8:05 PM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    A lot of first gens swear the diff drop isn't needed. Personally, I'm going to get one. Might as well nip it in the butt and not have to deal with it later.
  6. Apr 2, 2011 at 8:06 PM
    Madams
    South Carolina
    They call it barney
    Before I thought about getting 5100's I was looking at the 2.5 inch toytec spacer lift and it said it came with
    Brake Proportioning Valve Bracket- Needed to gain the correct brake proportioning back to the rear when lifting your rear suspension. Acted like I needed it.
    I looked at the 5100's and didnt say nothing about that I needed it. But Im going to get it any way
  7. Apr 2, 2011 at 8:16 PM
    Madams
    South Carolina
    They call it barney
    Yeah you right.
  8. Apr 2, 2011 at 8:27 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    i dont know what the break valve bracket is...but maybe an extended brake line??
  9. Apr 2, 2011 at 8:33 PM
    BoostingMS6
    Alex
    El Paso, TX
    Even then, you can get away with 2.5 inches of lift with the stock break lines.
    But yet again.. I chose to nip it and purchased stainless steel threaded lines 2.75 inches longer than stock.
