Making the 4lo warning chime less obnoxious.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Collins, Oct 14, 2011.
  1. Oct 14, 2011 at 8:37 AM
    Collins
    Collins [OP] Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Hi Folks,
    I would like to make my 4lo warning chime quieter. My truck still takes a bit
    of fiddling around to engage 4lo and that (4lo not engaged) buzzer is really loud to me.
    Where is the chime located? I was thinking i would put
    a pc. of tape or something over the component and that would
    make it less annoying.
    I did a search, but couldn't find anything on this?
    Is there a mod for this anywhere?
    I don't want to totally defeat the chime, just less loud.
    Thanks for any help.
    PC
  2. Oct 14, 2011 at 9:48 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Engage it and it doesn't make any noise at all.
  3. Oct 14, 2011 at 9:56 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Make sure you are at a stop if you want 4Lo to engage in a timely fashion. I believe the manual says you can do it at <3mph, but I still think its a good practice to stop.
    Unless you want to completely remove it, which probably isn't a great idea, why muffle it?
  4. Oct 14, 2011 at 10:55 AM
    Collins
    North Carolina
    I guess i don't use 4lo enough, but it is kind of hit or miss
    when i engage. I'm fully stopped, clutch ALL the way in...etc.
    The buzzer is unnecessarily loud to me is why.
    I checked a little more during lunch and it seems the buzzer/chime
    is behind the Glove box...
    just wondering if someone has done it?
    yea, i agree not a good idea to completely disable it.
    I'll do some more looking around this weekend if i have time.
    Thanks,
    PC
  5. Oct 14, 2011 at 11:07 AM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    x1,000,000 plus its not like you drive around with it buzzing
  6. Oct 14, 2011 at 11:14 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Maybe he does^^
  7. Oct 14, 2011 at 11:17 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Interesting...I've never heard a warning chime when engageing 4lo. Do the 07's even have it or is this something new?
  8. Oct 14, 2011 at 11:19 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    I thnk its only 08 and up
  9. Oct 14, 2011 at 12:46 PM
    Collins
    North Carolina
    Maybe you should have read my post first.
    I know how to engage 4lo.
    I made no mention of chopping at anything. I just want to put some
    tape or something over the chime to reduce the volume.
    This truck is tough to engage 4lo...like i said, i don't use 4lo much, so maybe that is the problem.
    Thanks for all the on topic help guys...
    and Christian, good luck getting your 30,000th post.
  10. Oct 14, 2011 at 12:53 PM
    kirkofwimbo
    kirkofwimbo Say no to Bro
    Clayton
    Wimberley, TX
    ‘17 TRDOR DCSB
    OP not to be rude, but if your are following the proper procedures you shouldn't be getting beeped at at all. Make sure the truck is already in 4H, come to stop, push clutch to floor and then switch to 4L
  11. Oct 14, 2011 at 12:54 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    2007's just have the blinking lights on the dash, no buzzer or chime. I've tried to engage it incorrectly before and it didn't make any noise, just lots of flashing lights.
  12. Oct 14, 2011 at 12:55 PM
    Gincoma
    Salt Lake City UT
    My 05 did it
  13. Oct 14, 2011 at 12:56 PM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘17 TRDOR DCSB
    My 2007 will beep at me....
  14. Oct 14, 2011 at 12:58 PM
    Pugga
    Massachusetts
    hmm... guess what I'm doing after work :D
    I'll go out and throw that bitch in 4lo and see what it does!
    Edit: I disabled all my other chimes like the door lock and seatbelt buzzer, would that affect it maybe?
  15. Oct 14, 2011 at 1:01 PM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘17 TRDOR DCSB
    Hmm, not sure. I don't have a seatbelt buzzer or beep on lock on mine, but it was like that when I bought it
  16. Oct 14, 2011 at 1:03 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    hey guys sorry to thread jack but when i put my turn signal on, its too loud and hurts my ears. is there any way to make it quieter?
    seriously, my ears bleed when i'm done driving...
  17. Oct 14, 2011 at 1:05 PM
    Pugga
    Massachusetts
    Same here, I've never had any chimes or buzzers. I just assumed the dealer disabled all that crap. :notsure:
  18. Oct 14, 2011 at 1:06 PM
    Pugga
    Massachusetts
    Earplugs :cool:
    If you find the buzzer, put some insulation over it to muffle the sound.
  19. Oct 14, 2011 at 1:07 PM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘17 TRDOR DCSB
    :laughing: I think you need to change your blinker fluid...that should help
    Ya idk how all that works...did you buy new or used?
  20. Oct 14, 2011 at 1:08 PM
    Pugga
    Massachusetts
    Brand spankin' new
