Making the front side marker lights blink as the blinkers are used.
Discussion in 'Lighting' started by Jpcustoms, Apr 18, 2017.
  1. Apr 18, 2017 at 6:29 PM
    Jpcustoms
    Jpcustoms [OP] New Member
    2011 tacoma prerunner 4.0
    265-70-r16
    Is there a way to make the side marker lights blink? I have a 2011 Tacoma and I'm going to install a switchback LED for my running/turn signal lights. Also LED headlights. I saw some tacos that have the outside marker lights blink opposite the turn signal lights. So it's like the blinker would turn on and as the blinker turns off the side marker light turns on and so on. Also when the headlights are on and the running light switch to white, the outside marker lights turn on, until the turn signal is used. Then the marker light turns on when the switchback light turns white, and off when the switchback turns Amber. It's a cool effect and I can't figur out how it happens. I'm going ALL LED up front. Any help would be GREATLY APPRECIATED... Thank you in advance for any help.
    Jody
  2. Apr 18, 2017 at 6:33 PM
    Twalt87
    Twalt87 Well-Known Member
    Travis
    Vancouver island Bc
    tbird95 likes this.
  3. Jan 27, 2019 at 1:15 PM
    tbird95
    tbird95 Well-Known Member
    British Columbia, Canada
    TRD sport SR5 V6 DC, LB, 4x4, Tow package
    4runner heated, signal, courtesy light side mirrors, rearview mirror w/compass, temp & backup cam w/ pop luck PL 5400, Interior lights/gauges, BHLM, grillcraft MX black. Third brake light LED swap, rear tail lights LED swap from 2011. 3" Toytec (Boss) Coil overs, rear TSB AAL Bilsteins, Light Racing UCA. TRD grill badge, VIPER Smart Start.
    Ok so if my headlights are on i get just the normal signal on but when headlights are off signal and marker flash together. Is there a way to get them to flash with headlights on?
