Making the main cabin one with the camper shell?
Discussion in 'Tonneau Covers, Caps and Shells' started by Freefolk, Nov 27, 2021.
  1. Nov 27, 2021 at 11:09 PM
    Freefolk
    Freefolk [OP] Got Milk?
    Tormund
    2018 Tacoma SR5 Access Cab
    Has anyone heard of someone removing the back glass on the 3rd Gen Tacoma and then removing the glass of a campershell to create a passthrough?
    Then you'd want to seal the shell and the truck with some kind of bendable rubber, incorporating weather stripping.
    I like to put my to go back behind by seat, so accessing clothing and other items up front would be easier.
  2. Nov 27, 2021 at 11:39 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Yes it’s called a 4runner
    MeefZah, D. Lengua, mcc1012 and 4 others like this.
  3. Nov 27, 2021 at 11:45 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Don’t do it. You’re overcomplicating your life.
    1st gen sequoia makes an awesome camping rig FYI. Pull out the back seats and you’ve got a big enough flat area for a full twin mattress and room along the side and footwells open. If you need access to the rear from the front seat, you’ve got the wrong vehicle.
    SUVs have their perks.
    jackn7 and TACOTU3 like this.
  4. Nov 28, 2021 at 12:20 AM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Are you afraid of the boogy man?
  5. Nov 28, 2021 at 12:32 AM
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    Looked into this a bit at one point. There have been camper shells that have a rubber boot around the whole front window, to seal against the back of the cab, but they just end up rubbing all the paint off the cab where it contacts, since there’s more flex between the bed and cab than you’d think. I tried something related, putting foam weather stripping between the cab and shell, around the small slider windows in both, but the first time I went off road the above flex problem became apparent when the foam twisted away from where I’d stuck it, and I gave up on the idea.
  6. Nov 28, 2021 at 3:00 AM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
