Making your non-functional hood functional
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vinchez78, Nov 26, 2020.
  1. Jan 7, 2021 at 8:27 AM
    cartter469
    cartter469 Professional Idiot
    Cartter
    TBD
    '17 4x4 DCSB OR
    Sliders; Skids; Diodes; 33" Falkens; Elka 2.5's; Icon Rxt
    Many people mount small light bars in there if they do not want to go with a full bar up top on the roof. Pretty interesting idea for a casual person to do. I would probably go that route if my truck had the scoop.
    mic_sierra and Traes12taco like this.
  2. Jan 7, 2021 at 8:28 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    because of the engine design, most people scrap them for a fmic anyways though
  3. Jan 7, 2021 at 8:29 AM
    cartter469
    Cartter
    TBD
    '17 4x4 DCSB OR
    This is true, the guys who want to make any power do this so they can get a much thicker intercooler as well as more surface area.
  4. Jan 7, 2021 at 8:53 AM
    Taco600mpg
    Taco600mpg Well-Known Member
    Cam
    14 regular cab 5 speed manual
    2.25 inch lift, Firestone airbags, 235/85/16 tires, k&n 63 series cold air intake, LCE header and exhaust, nfab prerunner light bar, trd skid plate 3rd gen oem knock off, ecometer, kc lights, trd grill emblem, trifold bed cover, cb radio and antenna, pedal commander, volant ram air scoop, daystar airbag cradles, trd off road 3rd gen rims, hood hinge light mounts, bilstein 5100 shocks and 5100 struts set at 1.75 lift, strut spacers to gain . 5 more inches of lift, Jba standard high caster upper control arms
    There’s no way a snorkel should help jp and mpg. It may be pressurized but if u go wide open it becomes restricted. I really should just cut a hole in the hood and just have my filter pop out of the hood
  5. Jan 7, 2021 at 8:56 AM
    Taco600mpg
    Cam
    I’m not looking for the scoop to be pressurized by the suction of the engine. But more have the air hit the filter much more force at low speeds like 35 mph and above
  6. Jan 7, 2021 at 10:14 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Kind of, the more bends or surface irregularities, i.e. corrugated tubing, the more turbulence you create (fluid dynamics). I'm no engineer or even auto mechanic, but I'll give you one simple example where everyone has noted an improvement- the heater tube under a VW bus. The factory piece is an aluminized, flexible corrugated tube. By replacing it with a smooth piece of galvanized ducting the defrost and front heat volume are noticeably increased, temperature is also higher meaning that the is moving faster (less time to cool down); adding insulation increases this even more. All of this has been measured but folks much smarter than me- not that that takes much. :anonymous: If the heater boxes are in good working shape, the old air cooled VWs are actually capable of producing enough heat to defrost the windshield and keep you warm. Most are in such bad shape at this point that the owner's have no idea what they're missing.
    Incidentally, the intercoolers on Mitsubishi Pajeros, Toyota HiLuxes, etc. are located under the hood scoops.
  7. Jan 7, 2021 at 11:35 AM
    Taco600mpg
    Cam
    I believe it will require more suction force to go through longer tubing even if the tubing is a snorkel. If the snorkel head was really really big then it could probably work better
  8. Feb 28, 2022 at 4:23 AM
    gearcruncher
    Canadain bumper technician
    Bumping for thoughts of direct injected fresh air
    With 17 horespower gains , I am thinking about this mod
    Key-Rei likes this.
  9. Feb 28, 2022 at 8:31 AM
    Icarus II
    Icarus II Well-Known Member
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    MAy be oversimplified but since the ECU adjusts engine parameters to maximize mpg, wouldn't the computer adjust for the lower incoming air temp?
  10. Feb 28, 2022 at 12:45 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Cold air is dense and will require more fuel avoid running lean. So yes, the ECU will fatten the mixture to compensate for the cooler air.
    And I understand it, the ECU is not maximizing MPG per se. It is attempting to maintain the stochiometric ratio between fuel and air.
  11. Feb 28, 2022 at 1:04 PM
    Icarus II
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    Isn't that to maximize mileage??
  12. Feb 28, 2022 at 1:07 PM
    Larzzzz
    Larry
    MA
    I guess. More for emissions in my mind.
  13. Feb 28, 2022 at 1:15 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    What function do you want it to serve when you say functional? Some have mounted a light bar in that spot. It is the perfect place for it.
  14. Feb 28, 2022 at 1:39 PM
    MR5X5
    MR5X5 Well-Known Member
    Stoichiometrically speaking - the ECU is not trying to maximized mpg, it is optimizing mixing ratio, which results in maximum burn efficiency which subsequently results in max MPG - minutia notwithstanding.
    Icarus II and blu92in99 like this.
  15. Mar 1, 2022 at 2:33 AM
    #35
    Larzzzz
    Larry
    MA
    If you are speaking stoichiometrically, shouldn't there be a hyphen for every 14 syllables? Lol
    Edit: 15 syllables.... I should have rounded up.
  16. Mar 1, 2022 at 3:09 PM
    #36
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    14.7 parts air to 1 part fuel is the best ratio for air molecules to combine with fuel molecules and have very little "waste" left over.
    Also, switching the fuel mixture above and below stoich helps feed oxygen into the converter. Converters store oxygen on purpose so it can be combined with CO and go out the tailpipe as CO2
