Manfred's #thicc boi aka 'White Rhino'
Discussion in '2nd Gen. Builds (2005-2015)' started by Manfred, Nov 17, 2017.
  1. May 23, 2019 at 9:49 AM
    #381
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    if you fill up at Perry Sound like we always do, you will have enough to get to trails (42KMs) wheel and comeback and you still probably have around 1/2 tank left.
    Your snorkel won’t suddenly start consuming 40L/100km lol
  2. May 23, 2019 at 6:12 PM
    #382
    Manfred
    Manfred [OP] Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    Snorkel plumbed, sealed and ready to take on some water. All in all pretty happy with how it turned out.
  3. Jun 2, 2019 at 7:24 PM
    #383
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    First camp out this season with the white rhino in Ardbeg, ON
    2019-06-02_22.07.51.jpg 2019-06-02_21.47.28.jpg 20190601_001339.jpg 20190601_001537.jpg 20190601_205832.jpg
    Got home and got the splash guards cut and installed. Thanks @llamasmurf :cookiemonster:
    20190602_162158.jpg 20190602_163232.jpg 20190602_165804.jpg 20190602_174814.jpg
  4. Jun 2, 2019 at 7:26 PM
    #384
    Norilsk
    Eugene
    What's that hanging thing inside the cap on the left at the top?
  5. Jun 2, 2019 at 7:27 PM
    #385
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    Lol the original cap seal. Like the plumbers pipe insulation. Dont know why I still have it haha
    Norilsk[QUOTED] likes this.
  6. Jun 3, 2019 at 1:38 AM
    #386
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Excellent!
    My bad on it taking so long to get in your fingers.
    Now pass it around to all the cunts :cookiemonster:
  7. Jun 18, 2019 at 6:16 PM
    #387
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    Screaming deal on a solar panel. 230W for 100 bucks. Massive though, need to mount and get a good MPPT charge controller. Any recommendations @Canadian Joe
    20190618_171736.jpg 20190618_185049.jpg 20190618_185033.jpg 20190618_185015.jpg
    Atlas86, tacoma16 and llamasmurf like this.
  8. Jun 18, 2019 at 6:25 PM
    #388
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    8BDB9C86-F65E-4BE4-88A9-6D6ED3D50F52.jpg Man that ARB fits like a glove!
    llamasmurf and Manfred[OP] like this.
  9. Jun 18, 2019 at 6:26 PM
    #389
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    I have it a little cockeyed gotta straighten it out but oh ya. Worked well when I ran into a tree by accident
    :anonymous:
  10. Jun 18, 2019 at 6:35 PM
    #390
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    llamasmurf likes this.
  11. Jun 18, 2019 at 6:46 PM
    #391
    llamasmurf
    Wes
    Northern Ontario
    No damage from that incident? :rolleyes:
    Get someone to help you correct it, its sooo much easier with help.:cookiemonster:
    Manfred[QUOTED][OP] likes this.
  12. Jun 18, 2019 at 6:47 PM
    #392
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    here that @tacoma16 youre my friend :]
    tacoma16 and llamasmurf[QUOTED] like this.
  13. Jun 18, 2019 at 8:03 PM
    #393
    Canadian Joe
    Canadian Joe Well-Known Member
    Joe
    Ontario
    2016 Tacoma trd off-road ,access cab,MT
    SCS rims 285's OME lift
    That's a big solar panel ,it may run a Prius :anonymous:
    This the exact system I have,got it on sale for around 200 dollars,
    https://www.canadiantire.ca/en/pdp/...4gIVT7jACh3z5Q3rEAQYASABEgLQ_PD_BwE&gclsrc=aw.
    My 100 watt system has kept my 60 litre fridge / freezer running for 2 week now with the fridge and freezer set at 0 C , with it mounted flat and not tipped up nor plugged into truck. Mine will tip up as I made some hinges with aluminum angle and bolts and made a small angle brace to hold it.
    I have a 27 group AGM deep cycle battery that is not connected to the truck charging system .
    I personally would not connect them as there is no chance for a failure that you cost you two dead batteries out in the middle of nowhere. I have the power cord from my fridge run right up beside my truck 12 volt on the console so when I driving I can plug it into the truck if needed .Make sure you get a controller that you can program it you are going to use an AGM battery as they need to be charged at a little higher volts then most of the programed AGM setting . I think it's around 14.6 volts Also I had problems when I first set it up running to fridge through the controller which apparently some time happens.When I call them on it they said connect the fridge directly to the battery and not to the controller, them it works fine.
    I eventually want to get a roof rack on the cab to mount the solar panel on as then I can keep the fridge running when the camper is not on. It sure spoils you when at work on a construction site and your lunch and drinks are cold in the summer .
    Hope this helps ,
  14. Jun 19, 2019 at 9:26 AM
    #394
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    So the dude is selling more as well. Got a hold of a storage locker full of them. The one I got my hands on was a YL 230 P-29b [https://pdf.wholesalesolar.com/modu...15.1053896689.1560960674-447264831.1560960674] So ill need a controller that can handle a 30V/230W/8.4A load, or is that just over engineering? I was looking to this one but it states it can handle loads of 220W on a 12V system. So i think i will need something bigger. I dont want to fry the system on the first day haha
    https://www.amazon.ca/dp/B075NQQRPD...d_r=5dc691e2-92ae-11e9-a872-f5a9f9ee9825&th=1
    I do have the second battery waiting to get mounted underneath the truck somehow/somewhere so if i can figure out what controller (and maybe a small 300w inverter) to use then i could move on to the next steps lol
  15. Jun 19, 2019 at 9:29 AM
    #395
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
  16. Jun 19, 2019 at 10:08 AM
    #396
    Canadian Joe
    Joe
    Ontario
  17. Jul 1, 2019 at 9:49 AM
    #397
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    @Atlas86 took the time to build this for me j just supplied the ammo can. Did a bang up job. Need a strip of fire resistant rope to make it air tight.
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Also need to organize these drawers a bit better. In need of some better cookware and less styrofoam plates other than that its beach camping for Canada Day:canada:
  18. Jul 5, 2019 at 7:48 PM
    #398
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    #oof
    Time for full skids
  19. Jul 5, 2019 at 8:17 PM
    #399
    Norilsk
    Eugene
    Time for real armour! Mobtown has sale right now :boink:
  20. Jul 6, 2019 at 3:07 AM
    #400
    llamasmurf
    Wes
    Northern Ontario
    It looks like that splash guard did not consent, but you just kept going. o_O
