Manifold caked with filth
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rat_Bastard, Nov 19, 2023.
  1. Nov 19, 2023 at 5:00 PM
    Bishop84
    Bishop84 Well-Known Member
    Next issue is scoring in the cylinders.
    I'd be really concerned if I had this, I'd remove the manifold to clean it for sure.
  2. Nov 19, 2023 at 5:01 PM
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    musicisevil and Junkhead like this.
  3. Nov 19, 2023 at 5:04 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Wow, that engine is not long for this world...
    This is why you don't use a K&N folks!
  4. Nov 19, 2023 at 5:05 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    There is no way this is the K&N filters fault. I have used them for years on multiple vehicles and never had anything like this happen. Something else is going on here.
  5. Nov 19, 2023 at 5:20 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    No, it is the K&N.
    As specks of dust pass through the filter gauze, tiny amounts of the filter's oil get left on the specks, allowing them to cling to whatever other surfaces they might touch. Eventually the specks (and oil) starts to build up, and you end up with the mess seen here.
    I learned this 20 years ago when my Ford Ranger 4x4 (4.0L V6) slowly started running like crap and throwing codes whenever I gave it sustained throttle (such as driving up long highway grades or towing a trailer).
    The whole intake looked exactly like the picture, the MAF sensor element was almost fully buried in it, and it ruined the o2 sensors as well (all at 60K miles).
    After cleaning the MAF & intake, replacing the o2s and putting in a clean PAPER filter, things were good again (intake remaining clean as well). What's unknown is how much additional engine wear all that dust going through it caused.
  6. Nov 19, 2023 at 5:31 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    yep, k&n filters will do that.
    know a guy that used to maintain sport bikes at a shop, saw multiple motors get wrecked with k&n filters...
    i'll never run more than the oe paper filter.
  7. Nov 19, 2023 at 5:34 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    The OEM TRD air filter is an oiled filter just like the K&N. Toyota wouldn't offer it if they did this. I'd say something else has went wrong here.
  8. Nov 19, 2023 at 5:41 PM
    soundman98
    NW Indiana
    high flow
    good filtration
    re-usable
    pick 1.
    trd could easily offer it because the majority of people would use it on-road.
    ironically, this exact same discussion where i met that guy that used to repair sport bikes and saw the engine damage was on a sports car forum.
    Chew and wrightme43 like this.
  9. Nov 19, 2023 at 5:45 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Damn. Performance air filters really don’t seem to perform well at filtering air.
    That’s a lot of buildup. Almost surprising no codes thrown. This would be an 8/10 on my scales of a serious issue vehicle-wise.
    An oil analysis on this engine would be neat.
    Best of luck getting it cleaned up. Hopefully no issues rise because of this.
    Rat_Bastard[OP] likes this.
  10. Nov 19, 2023 at 5:46 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Slightly OT. I purchased the K&N cabin air filter, haven't installed it yet. I think I will stick with the OEM HEPA filter.
  11. Nov 19, 2023 at 5:51 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  12. Nov 19, 2023 at 5:52 PM
    eurowner
    eurowner Duke Sky
    Scoty
    I have been using the K&N Cabin filter for 3 years in my ‘17 Tacoma with no problems, easy to clean and recondition, and less waste in the land fill.
    Jerry311SD, Big tall dave and VB25 like this.
  13. Nov 19, 2023 at 5:57 PM
    33yrsoftoys
    joel
    mid Michigan
    The OEM TRD oiled air filter maintains all factory warranties. If oiled air filters caused this Toyota wouldn't offer, or warranty them. Something else has went wrong here.
  14. Nov 19, 2023 at 6:00 PM
    VB25
    2018 TRD OR ACLB AT
    K&N cabin filters are excellent. Fine filtration isn’t required for the HVAC system, and our cabin filters fill up faaast. I’d probably go through 4 disposables a year without mine.
    Big tall dave and eurowner like this.
  15. Nov 19, 2023 at 6:04 PM
    #35
    VB25
    2018 TRD OR ACLB AT
    Truck is 7 years old and 140k with this buildup. And still works. Of course Toyota doesn’t care about oiled filters. Long out of warranty.
  16. Nov 19, 2023 at 6:06 PM
    #36
    MGMDesertTaco
    The intake box has a mesh/cotton filter screen. There's got to be something else besides the k&n that has contributed to this.
  17. Nov 19, 2023 at 6:09 PM
    #37
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol looks like no filter. You sure you didn't bypass the filter with the snorkle?
  18. Nov 19, 2023 at 6:11 PM
    #38
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Never done a throttle body clean is my guess, would of caught that sooner. IIRC those are every 30-35K miles.
    Used to live in AZ. Learned my lesson with K&Ns years ago in my old truck. oil will be sucked off them coating the MAF that makes it throw a code. Went back to paper, hadn’t a problem since.
    Looks you have two issues, pulling oil off the filter (perhaps over oiling it) and an air leak.
    Think I would trade that truck in sooner rather than later.
    wrightme43 and hiPSI like this.
  19. Nov 19, 2023 at 6:35 PM
    #39
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Looks like a 50 year old sewer pipe at a Taco Bell.
  20. Nov 20, 2023 at 3:11 AM
    #40
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    that you live, where?
